• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
link a logo via div
Enthusiast ,
Jan 12, 2018 Jan 12, 2018
CSS-Tricks mentioned that to hyperlink your logo you can surround a div with the <a> tags.
<a href="http://example.com"> <div> anything </div> </a>
How would it work in this case?
<div class="col-sm-12 col-lg-12 clearfix">
       <a target="_blank" href="#"><div class="logo"><img src="images/logo.png" class="img-responsive" alt="Logo"></div></a>
</div>
I tried this but it did not seem to work. I tried it on a local server for testing. Can you advise if something is incorrect here?
Thank you!
Views
544
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , Jan 12, 2018 Jan 12, 2018
Seems pretty straightforward.  No reason it shouldn't work.
<DIV>
    <A>
        <DIV>
            <img />
        </div>
    </a>
</div>
V/r,
^ _ ^
Votes
Translate
Translate
LEGEND ,
<DIV>
    <A>
        <DIV>
            <img />
        </div>
    </a>
</div>
V/r,
^ _ ^
Votes
Translate
Translate
Report
Report
Community Expert ,
Adding to WolfShade​ reply, you will have to replace the '#' in <a target="_blank" href="#"> with the destination such as
<a target="_blank" href="myPage.html"><div class="logo"><img src="images/logo.png" class="img-responsive" alt="Logo"></div></a>
As a side note: Because Bootstrap 3+ is a mobile first framework it is not neccessar to add all of the classes as in <div class="col-sm-12 col-lg-12 clearfix">. You can remove the class for lg as in
<div class="col-sm-12 clearfix">
Wappler, the only real Dreamweaver alternative.
Votes
Translate
Translate
Report
Report
Enthusiast ,
Feb 07, 2018 Feb 07, 2018
I cannot get this specific use case to work:
    <div class="logo">
     <a target="_blank" href="https://www.google.com"><img src="images/logo.png" class="img-responsive" alt="The Logo"></a>
     </div>
</div>
I just need the .png of logo to link out actively. As is, it does not work at all. Do the <a> tags get pulled out and surround the logo div class instead?
Thank you.
Votes
Translate
Translate
Report
Report
LEGEND ,
No.  Unless there is some extenuating circumstance, the code you provided should work.  What, precisely, isn't working?
V/r,
^ _ ^
Votes
Translate
Translate
Report
Report
Enthusiast ,
Feb 08, 2018 Feb 08, 2018
OK, I see what's happening here.
Within same overall header, there is this immediately after the code container that houses logo, and it overlaps the logo so is blocking out the logo link capability. What's below represents the navicon menu control that comes into play when screen is collapsed.
<div id="headerToggle" class="header-bottom">
            <div class="container">
            <div class="row">
             <div class="col-sm-4">
              <div class="navbar-header">
                <a class="navbar-toggle" role="button" data-toggle="collapse" href="#collapseExample" aria-expanded="false" aria-controls="collapseExample">
                 <span class="sr-only">Toggle navigation</span>
                <span class="icon-bar"></span>
                 </a>
</div> </div> </div></div></div>
**I tried adding z-index: 9999 !important;  to the div called 'logo' to try to force it to be "top dog". This did not work.
Any other ideas?
Votes
Translate
Translate
Report
Report
Community Expert ,
z-index only works on items that are positioned via css.
Since you have elements overlapping, I'll assume that at least one of them has position:absolute in its css. The other element, I'd be willing to bet, doesn't have any positioning setting at all, which would cause z-index to fail.
You can add position:relative to the non-positioned element, then z-index settings will function.
Votes
Translate
Translate
Report
Report
Enthusiast ,
LATEST
Genius! - YES, it worked!
Thank you!
Votes
Translate
Translate
Report
Report
