9 Replies Latest reply on Jan 14, 2018 4:10 AM by hatstead
    Rounded border
    mcdon47 Level 1
      How do I draw a rounded border? When I searched for solutions, a lot were about how to draw rounded rectangles or rounded corners but I want to insert a rounded border. Thanks.
        • 1. Re: Rounded border
          hatstead Adobe Community Professional
          Have a look at the Shape Selection tool (Keyboard short-cut U).
          There are many shapes, e.g. Crescent Moon, etc.
          • 2. Re: Rounded border
            Mark Sand Level 4
            1.  Select the Rounded Rectangle tool. Set Radius (size of rounded corner) to a large value (in this example I used 80 px).
            2.  Draw out rectangle, creating a new layer. Ctrl-click the layer to select just the shape and delete the layer (for purposes of the example I just turned off its visibility).
            3.  Create a new blank layer and Edit>Stroke. I used a value of 50 px. Location Inside gave the best result; Center and Outside gave corners that were not quite well rounded.
            • 3. Re: Rounded border
              mcdon47 Level 1
              Thank you. There are all sorts of fancy shapes but none that is a rounded border.
              • 4. Re: Rounded border
                mcdon47 Level 1
                Thank you but I do not think you have finished your sentence? Step no 3.... I selected Edit>Stroke and there there another rounded rectangle but what then??
                • 5. Re: Rounded border
                  Sorry, but I misunderstood what you are looking for. Try this:
                  1. Open picture file. This will be the background layer.
                  2. Access the Rounded rectangle tool. It is nested in a slot in the shape selection tool - press U a couple of times to get to it.
                  3. Set the radius to 60-80, and drag out the rectangle. This will generate a new layer. Shut off the visibility of this layer by clicking on its eye icon in the layers palette.
                  4. Press CTRL+left click on the layer thumbnail (not the name) to make the shape active. You should see "marching ants."
                  5. Open a blank layer at the top.
                  6. Go to Edit>Stroke(outline) selection. Make stroke 4-5 px, place it inside.
                  7. Press CTRL+D to get rid of the marching ants.
                  • 6. Re: Rounded border
                    Mark Sand Level 4
                    I should have mentioned to enter the stroke size (width of the border).
                    Hatstead did in his instructions (same as my instructions).
                    Let us know if you have success.
                    • 7. Re: Rounded border
                      mcdon47 Level 1
                      Thank you, it works.
                      • 8. Re: Rounded border
                        mcdon47 Level 1
                        • 9. Re: Rounded border
                          You're welcome. Glad to help.
