1 Reply Latest reply on Jan 13, 2018 5:39 AM by Davide_Barranca
    Upload file from Javascript Socket to Golang API (Gin Gonic)
    adriend45871304
      I am trying to upload a file to my server (Golang) from a photoshop script (javascript)
      Here is the service reading the file on the server:
      func Post(c *gin.Context) {
          // Read uploaded file
          file, header, err := c.Request.FormFile("file")
          if err != nil {
              c.JSON(utils.BuildError(err))
          if file == nil {
              c.JSON(utils.BuildError(errors.New("no file provided")))
              return
          // Get Client's informations ready to be processed
          var inputDTO InputDTO
          inputDTO.File = file
          inputDTO
      .Name = header.Filename
          c.JSON(utils.BuildResponse(inputDTO.addService()))
      I tested it using this curl request and it works as expected:
      curl -i -X POST -H "Content-Type: multipart/form-data" -F "file=@FILE.pdf" localhost:14000/api/v2/items
      Result:
      c.Request.Header => map[Content-Length:[787347] Expect:[100-continue] Content-Type:[multipart/form-data; boundary=------------------------b01a62679831e49b] User-Agent:[curl/7.46.0] Accept:[*/*]]
      c.Request.Body => &{0xc0422a6000 0xc042280180 false false}
      header => [some binary]
      file => {0xc042080930}
      Now, Photoshop javascript only allows the usage of Socket, so I use this script:
      function sendDataToServerLocal(filepath, filename) {
          conn
      = new Socket;
          reply = "";
          // Read file
          var f = File(filepath);
          f.encoding = 'BINARY';
          f.open("r");
          var fContent = f.read();
          f.close();
          // Connect to server
          if (conn.open("127.0.0.1:14000", "BINARY")) {
              conn.timeout = 20000;
              boundary = Math.random().toString().substr(2);
              content = "--" + boundary
      + "Content-Disposition: form-data; name=\"file\"; filename=\"" + filename + ".pdf\"\n"
               + "Content-Type: application/octet-stream\n"
               + "\n"
               + fContent;
              cs
      = "POST /api/v2/items HTTP/1.1\n"
               + "Content-Length: " + content.length + "\n"
               + "Content-Type: multipart/form-data; charset=utf-8; boundary=" + boundary + "\n"
               + "Host: 127.0.0.1:14000\n"
               + "User-Agent: Apache-HttpClient/4.3.1 (java 1.5)\n"
               + "Accept: */*\n"
               + "Expect: 100-continue\n"
               + "\n"
               + content
      "--" + boundary + "--\n"
              conn
      .write(cs);
              reply = conn.read(999999);
              conn.close();
              if (reply.indexOf("200 OK") > 0) {
                  alert("File successfully uploaded!");
              } else {
                  throw new Error("Error:" + reply);
          } else {
              throw new Error("Can't connect to server");
      And I get the same nice request, but header and body are nil...
      c.Request.Header => map[User-Agent:[Apache-HttpClient/4.3.1 (java 1.5)] Accept:[*/*] Expect:[100-continue] Content-Length:[787299] Content-Type:[multipart/form-data; boundary=XLuvdG51D_BRiiAda_0y79ImMN_ddtKYzeFFLlu8]]
      c.Request.Body => &{0xc042278380 0xc04204e2c0 false false}
      header => nil
      file => nil
      Any idea of why the file is nil when sent from the Socket?
      Thank you!
        • 1. Re: Upload file from Javascript Socket to Golang API (Gin Gonic)
          Davide_Barranca Level 1
          I've used GET request via Socket in the past, not POST. E.g.
          var reply = "";
          // The HTTP Request string
          var req = "GET http://currentmillis.com/time/minutes-since-unix-epoch.php " +
                    "HTTP/1.1\r\nHost: currentmillis.com\r\nConnection: close\r\n\r\n";
          conn = new Socket();
          if (conn.open("www.currentmillis.com:80", "binary")) { // 188.121.45.1
              conn.write(req);
                  $.writeln("Full Reply ---------------\n" + reply);
                  conn.close();
                  $.writeln("Minutes since Unix epoch: " +
                       reply.substr(this.reply.indexOf("\r\n\r\n") + 7, 10));
          Any chance you can use a CEP Panel, that would be easier...
          Davide
