3 Replies Latest reply on Jul 10, 2008 8:40 AM by kglad
    Tween on an Curve (k)
    Level 7
      I know this can be done because I've done it before, but I cannot find
      the file since it was around 6 or 7 years ago.
      I want to tween an object on half circle arch. Needs to be ActionScipt.
      I know it has something to do with sin and cosin, but beyond that I
      cannot remember.
      I don't think it a true Tween class, but maybe some sort of loop.
      Actually, I'll take any solution you can give.
      -Kirk
        • 1. Re: Tween on an Curve (k)
          this is from a CurveTo class that i wrote a while ago. you can use easing if you want to call the following function repeatedly passing a parameter t that can vary from 0 to 1 and defining the other obvious parameters (_loops = number of complete loops, _xAx = x-radius, _yAx = y-radius (these should be equal for a cirle), _fx = x-center, _fy = y-center).
          • 2. Re: Tween on an Curve (k)
            Level 7
            Thanks for the code. It's a little advanced for me.
            To try it, I made a movieClip and put it on the stage and called it "_tgt"
            Then I made an Actions layer and put the following in there:
            _loops=3
            t=1
            _xAx=30
            _yAx=30
            function ellipseF(t) {
            var ang:Number = t*Math.PI*2*_loops;
            _tgt._x = _fX+Math.cos(ang)*_xAx;
            _tgt._y = _fY+Math.sin(ang)*_yAx;
            When I test it, nothing happens.
            > function ellipseF(t){
            • 3. Re: Tween on an Curve (k)
              you must call ellipseF(t) repeatedly and pass t as it varies from 0 to 1 (if you want _tgt to complete 3 loops around your circle) and you need to define the circles center, _fx,_fy.
