7 Replies Latest reply on Jan 18, 2018 9:29 PM by older
    Get date Taken to be the only date used??????
    older Level 1
      Windows does terrible things with the dates photos were taken & decides that date transferred to PC should be that date rather then when it was actually taken. This is nonsense.  If you copy photo to another drive it seems to do the same thing again.
      How can you stop this & ALWAYS HAVE DATE TAKEN as per EXif Data?
        • 1. Re: Get date Taken to be the only date used??????
          MichelBParis Adobe Community Professional & MVP
          Don't be fooled by what is displayed vs what is used (or recorded) in Windows or in the Organizer.
          Windows stores about 15 kinds of dates, and you can choose which will be displayed, including the 'date_taken' you are referring to.
          The organizer will show the 'date_taken' which is the relevant info to manage photo files. That's the date shown on the thumbnails in 'detailed' view. The Info panel on the right can also display other dates.
          Of course, the 'date_taken' is only relevant for photos coming from camera with the exif date. For scanned photos, the 'date_taken' is unknown and replaced by the creation date (when the photo file has been created).
          • 2. Re: Get date Taken to be the only date used??????
            older Level 1
            At the moment the library isn't displaying either the file name or the tags that had previously been there.
            Where can I find those 15 types of dates & where can I use them?   Can they be displayed in Windows Explorer?
            • 3. Re: Get date Taken to be the only date used??????
              You mean the organizer browsing space.
              To display the file names and dates, switch to detailed view from the menu or the shortcut Ctrl D. Be sure to set the zoom for individual thumbnails big enough and in the 'View' menu, be sure to tick both show file names.
              Yes you can display them in Windows Explorer.
              Set the View menu to 'detail'. Right click on the columns title bar and use the 'other' option on the bottom to display all the columns types you can add to the display.
              Photoshop Elements 6/7/8 Frequently Asked Questions (FAQ)
              • 4. Re: Get date Taken to be the only date used??????
                older Level 1
                As I said I am getting the date taken displayed below each thumbnail.  It appears that the true file name is still exists but isn't being displayed.  If I search in Windows Explorer I can find a photo that I want, by using the file name.  If I enter the same name in PSE 11 I get the same photo displayed but the name isn't displayed beneath the thumbnail, only the date taken appears.
                So the file name still appears to exist but PSE isn't seeing or displaying it even though it can find it.  I'm guessing that it's a Windows 10 problem.  Maybe the same problem accounts for the fact that no tags against each thumbnail even though they can be scrolled down in the tags list.
                What do you think & how do I fix this?
                • 5. Re: Get date Taken to be the only date used??????
                  It's not a Windows 10 problem.
                  1 - Use the 'detailed' view - shortcut Ctrl D (what you are correctly doing)
                  2 - View menu: be sure to tick all options including show file name
                  3 - Set the zoom for the thumbnail size big enough for the above information to display
                  4 - Keep the Information panel visible on the right, all the tags are shown in the 'image tag' section in the bottom.
                  Searching by file name:
                  It's an option in the find menu.
                  Did you try the new search view (magnifying glass on top right) if you have Elements 2018?
                  • 6. Re: Get date Taken to be the only date used??????
                    older Level 1
                    Great.  I now have the names appearing under the thumbnails.  I can see thumbnails if I click media or places but can see the thumbnails, but if I click people or events, I see none.  There had been tags for people & events as well.  In fact if I click on the scroll down tab for tags I can see listings for birthdays, weddings etc.  That's strange but at least we are moving in the right direction.
                    Perhaps I should re install PSE? What do you think?
                    • 7. Re: Get date Taken to be the only date used??????
                      older Level 1
                      If I created a new folder for the library & then told the program to get its data from the original library would that help?  Is it possible to set the program to search all drives,or selected drives to look for music files?
                      Thanks in advance
