5 Replies Latest reply on Jan 16, 2018 2:01 PM by Ahmed Yousef
    shadows
    yasmins40363890
      hi ,
      just wondering if any one can help .. im trying to remove some shadows from a wall behind 3 people but im struggling to do so..
      any help would be much appreciated
      thank you
      yas
        • 1. Re: shadows
          Ahmed Yousef Level 2
          The Content-Aware Fill feature is a useful for removing shadows
          Step1
          Open the image with the shadow you want to remove in Photoshop, and then press "Ctrl-J" to create a new duplicate layer of the image so that you can edit it in a non-destructive manner.
          Step2
          Select the Magic Wand tool, and then click the shadow. Increase the tolerance value if not all of the shadow is selected; decrease the tolerance value if more than just the shadow is selected. Click the shadow again after adjusting the tolerance to make a new selection. Alternatively, use the Quick Select tool or Lasso tool to select the shadow.
          Step3
          Click "Edit" from the menu bar, and then select "Fill." Alternatively, use the "Shift-F5" shortcut to display the Fill window.
          Step4
          Select "Content-Aware" from the "Use" drop-down list, and then click "OK."
          Step5
          Right-click the highlighted area and select "Deselect" from the context menu.
          • 2. Re: shadows
            Another way
            use the Adjustment Layers
            Step1
            Open the image with the shadow you want to remove in Photoshop.
            Step2
            Step3
            Click "Layer | New Adjustment Layer | Brightness/Contrast | OK."
            Step4
            Click and drag the "Brightness" slider to the right to decrease the brightness of the shadow until it matches the rest of the picture; click and drag the contrast slider to the left in order to decrease the contrast between the shadow and the surrounding image.
            Step5
            Create a new adjustment layer, and then adjust the hue and saturation if the brightness and contrast settings are not enough to match the shadowed area to the rest of the picture.
            • 3. Re: shadows
              Trevor.Dennis Adobe Community Professional
              Hi Yas
              We can't give you a definitive answer without seeing the image, as the particular circumstances make all the difference regards dealing with them.  JUst copy the image, and past into this thread with Ctrl v (Cmd v)
              • 4. Re: shadows
                yasmins40363890 Level 1
                Thank you, this is the photo.. its the 3 shadows behind the 3 people standing.
                • 5. Re: shadows
                  Try the Shadow\Highlight adjustment
                  Image > Adjustments > Shadow/Highlight.
