I'd like to set up a 3 way walking puppet similar to the Maddy, but with the exception that it could remain still in a left or right profile instead of reverting to the frontal profile.
My first attempt was to use have 5 groups, Frontal, Right Profile, Left Profile, Right Profile Walking and Left Profile walking and then just use a swap set with latches. It doesn't seem to work though.
Is it possible to do it with just 3 layers? Ie Could Maddy stop and face left?
Try this: Create a swap set for the three views. Then make the left view the default, and add a trigger to show the front view.
Hey spencere,
Did you try KJerryK's suggestion? Did it help?
Let us know.
Rameez
It gave me a good idea for something. I wanted something with a little more versatility. I basically have a body swapping (Front, Left Profile, Right Profile) layer under the Default Frontal.
Frontal
-Head swapping (Group)
-Body swapping (Group
---Frontal
---Left Profile (standing)
---Right profile (standing_
Left Profile
-Normal setup for walking
Right Profile
-Normal Setup for walking
I can trigger the Frontal body swapping before the movement, (ie Left profile body) and when it stops walking it faces the same direction (ie Left Profile Body).
