1. Re: How to batch rename images in a folder, but not in serial as previously?
teachbit Jan 15, 2018 6:35 AM (in response to Jackveer)I would rather take Bridge. If I understood you the right way, you want to look at the image and then decide what name to give.
2. Re: How to batch rename images in a folder, but not in serial as previously?
BarbBinder Jan 15, 2018 6:44 AM (in response to Jackveer)3 people found this helpfulShuffle, rename but also change the document name for each one? Not natively within Photoshop or Bridge.
What operating system are you on? Here's a way to use Terminal on a Mac to do it:
Terminal Tips: Generate random filenames for digital photo frame images
And a script for Windows:
Stupid Geek Tricks: Randomly Rename Every File in a Directory
Work on a copy of the original folder/
~Barb
3. Re: How to batch rename images in a folder, but not in serial as previously?
Jackveer Jan 15, 2018 6:59 AM (in response to BarbBinder)Barb, you got it exactly right about what I am looking for. I am using Windows 10 platform so I guess first resolution you provided(for MAC) is not for me.
About second option, I had come across it and tried it as well but nothing happened. May be I did something wrong! I will try it again though.
Just incase you come across any other tool/software for Windows platform please let me know.. I badly need solution for this.
4. Re: How to batch rename images in a folder, but not in serial as previously?
Jackveer Jan 15, 2018 7:02 AM (in response to teachbit)Hello,
I tried Bridge.. it does great for 'Batch Rename' but in a systematic and serial manner, while I am looking for random renaming tool/solution.
5. Re: How to batch rename images in a folder, but not in serial as previously?
BarbBinder Jan 15, 2018 7:30 AM (in response to Jackveer)Is this to prep photos for a photo frame, or a different application. Maybe if we understand the why behind the question we can offer an alternative workflow. For example, if this is a photo frame question, in Bridge you can reorder the files a number of ways—including manually—and then batch rename them with numbers in the front.
~Barb
6. Re: How to batch rename images in a folder, but not in serial as previously?
Jackveer Jan 15, 2018 7:36 AM (in response to BarbBinder)I want to use these images as background images for inspirational quotes..I do it as batch process which applies no. 1 text quotes on no. 1 image. Now I want these quotes on different images. for this, these same set of images must be shuffled and renamed.
7. Re: How to batch rename images in a folder, but not in serial as previously?
Jackveer Jan 15, 2018 7:40 AM (in response to BarbBinder)Bridge helps renaming in may different ways but sequence of images remain same even after renaming... while I want sequence changed by renaming..
8. Re: How to batch rename images in a folder, but not in serial as previously?
SJRiegel Jan 15, 2018 11:24 AM (in response to Jackveer)There are third-party file-naming software options that will allow you use an excel sheet to pair the names you want with the existing names, and then apply the remaining automatically.
The one I use is called A Better Finder Rename, but I'm sure there are others that would do the same job.
9. Re: How to batch rename images in a folder, but not in serial as previously?
Jackveer Jan 15, 2018 9:58 PM (in response to SJRiegel)Hello SJRiegel A Better Finder Rename tool is only for Mac OS, while I'm looking one for Windows 10 platform.
10. Re: How to batch rename images in a folder, but not in serial as previously?
Jackveer Jan 15, 2018 10:04 PM (in response to BarbBinder)Hello Barb, I tried Stupid Geek Tricks link you had shared. It doesn't work in Windows 10. Could you find something else? I badly need this. Thank you.
11. Re: How to batch rename images in a folder, but not in serial as previously?
Jackveer Jan 15, 2018 10:38 PM (in response to Jackveer)Hello All,
I guess I've found the tool which provides what I was looking for exactly. It's called Ant Renamer
[link removed ussnorway]
12. Re: How to batch rename images in a folder, but not in serial as previously?
BarbBinder Jan 16, 2018 4:49 AM (in response to Jackveer)Glad you found something that works!
~Barb
