• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
In "Photoshop" > "File" > "File Info" >"Camera Data" How do I fill in the "Owners" name???
New Here ,
Jan 15, 2018 Jan 15, 2018
In "Photoshop" > "File" > "file Info"n> "Camera Data"..How do I fill in the "Owners" name .???
[Moderator's note: This is a public forum. Your personal contact information was removed for your protection.]
Views
570
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Jan 15, 2018 Jan 15, 2018
Hi Anthony:
As a heads up, this is a user-to-user community forum. Users like you and I volunteer here in their spare time to answer questions on the applications they know well.
Your camera should have come with a program you can use to add your personal data. Once entered, Photoshop will read it.
~Barb
Votes
Translate
Translate
Adobe
New Here ,
Is this question too hard to answer or what??? Again ...In "Photoshop > "File" > "FILE INFO" > "Camera Data" How do I
fill the "Owners" name ??? Anthony Presson
Votes
Translate
Translate
Report
Report
Community Expert ,
Hi Anthony:
~Barb
Votes
Translate
Translate
Report
Report
LEGEND ,
The 'Camera Data' XMP panel displays the EXIF tags, which contains hardware-related data like the lens specifications. Photoshop does not allow editing of EXIF data through the File Properties panel, because many camera manufacturers have proprietary data encoded within the EXIF structure that nobody else (including Adobe) understands. The EXIF data is also used to apply profile corrections, so changing it can cause problems.
It is possible to manually replace EXIF tags using Photoshop scripting, or third-party software such as ExifTool, but you need to understand the tag structure in detail.
The tag you are referring to (Exif.Photo.CameraOwnerName) is not the same as the "copyright" text which can be entered using the menus on DSLRs. For many cameras it's inaccessible and on others you need to use the manufacturer's own software - for example on Canon EOS cameras it must be set using the EOS Utility software.
Votes
Translate
Translate
Report
Report
Community Expert ,
I'm learning this just now, although if I sell or trade in my camera I probably would have to remember to erase the name.
Gene
Votes
Translate
Translate
Report
Report
LEGEND ,
That's why camera rental shops, colleges, etc. often set the tag - it's not obvious how to change it, but very easy to see (in Photoshop, and when images are shared online with the EXIF data intact). Of all the EXIF tags that Photoshop could display in the properties panel, CameraOwnerName seems rather obscure until you think of it as an anti-theft system.
Votes
Translate
Translate
Report
Report
Community Expert ,
Jan 16, 2018 Jan 16, 2018
If all else fails, there's always Bridge
Canon
Canon DLC: Article: Adding Copyright information to your images
I am sure all models and makes will have the information in the camera's manual.
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
Have you actually tried to edit EXIF tags in Bridge? Notice anything missing? An edit button perhaps?
Votes
Translate
Translate
Report
Report
