1 Reply Latest reply on Jul 8, 2008 2:04 PM by kglad
    LoadVars OnLoad error message
      I'm having trouble using the onload method in the following code. I keep receiving the error message, "Left side of assignment operator must be variable or property" on the line of code that reads:
      contactLV.onLoad(success) = function() {
      Below is the code from the frame:
        • 1. Re: LoadVars OnLoad error message
          this[_parent.fields_descriptions [1]]
          doesn't makes sense when this refers to sendButton and your array is defined on the timeline that contains sendButton.
          if your_name, for example, is an object, you would use the following to resolve "your_name" into the object:
