Does anyone know how I go about creating a rectangle that has text cut out? See attached image for example.
Just draw a rectangle with a White Stroke and NO Fill
Then you can use the Scissors Tool and cut it.
When you use the Scissors Tool on a closed shape like rectangle you will have to click 2 points on the rectangle path to cut it.
cut 2 points above and another below.
here is a video for this:
https://indd.adobe.com/view/6ceb699e-925a-485d-be67-b68f49f80cd8
You want to cut out the text from the water colored background?
I'm looking to cut out the text from the white frame / rectangle
Sorry it was a wrong link, this is the link:
one way of doing it purely with appearances (on point type). apply a stroke, drag it below the 'characters' object, use Effect > convert to shape > rectangle with relative minus values top and bottom. apply another stroke, drag it to below characters but above the rectangle, give it a suitably chunky stroke weight, give it opacity 0%, set the whole object to knockout group.
