Hello all.
I'm with a issue on InDesign CS6, I can't use fit frame to content on a text box ended with "-".
I'm using the "-" as a separator between a text with a paragraph style and a number with a different style. There is no character or space after the "-" (space after also doesn't work).
My guess is that InDesign interprets the "-" as a hyphen and don't let me use fit frame. When I change the "-" for any other character ( ; : . | + ) the function works.
So, my question is: How do I tell InDesign to interpret the "-" just as a character? Or how can i use fit frame to content in this case?
Ps. Hyphenation ON or OFF is indifferent.
Thanks!!
Kauan
Hi Barb,
this issue was a bug in CS6 that is fixed now.
A workaround would be to use a character like an "l" after the dash and format it with no fill, 0.1 pt size and horizontal width of 1%. For that one you would apply a character style.
Regards,
Uwe
Hi kauansales ,
I keystroked this to see if a non-breaking hyphen was any different, but it worked as expected. What other variables are in play? Font? Version? Reference handle in the proxy?
~Barb
Hi Barb,
Regards,
Uwe
I never encountered that, Uwe. Thanks for letting us know!
So kauansales, I'm going to mark Uwe's answer as correct—you can update InDesign or follow his work-around.
~Barb
Hi, in this case I use the following:
Thanks everyone for your time and help!!!
I'll try to update to the latest version of InDesign CS6.
If still not working, i'll use one of the workarounds suggested.
Thanks!
Kauan
Hi Kauan,
to make that clear: The bug was never fixed with CS6.
I tested with CS6 8.1.0.
Regards,
Uwe
