• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
change image placeholder
Participant ,
Jan 17, 2018 Jan 17, 2018
Hi there,
I want to replace this bonsai vase image with another image. Does someone please can tell me how I can do it?
Thanks in advance,
Nico
Views
4.2K
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , Jan 19, 2018 Jan 19, 2018
close the mask
you can see it's open also because there is no mask mode available for it:
Votes
Translate
Translate
Community Expert ,
While Bonsai_01 is selected in the Timeline, start to drag and drop the source footage item that you would like to replace is with and then add the Alt key before you let go of the mouse.  Adding the Alt key tells AE that you want to replace the source of the selected layer.
Votes
Translate
Translate
Report
Report
LEGEND ,
Got an image in the same general shape as the masked thingy in the top shot?  Use the masked whatever in the top shot as a track matte for your other image.
Votes
Translate
Translate
Report
Report
Participant ,
hi Both,
thank you for your Tipps. I actually want to replace the vase with a pallet form mask image like this on photo belove.
Maybe I can use Photoshop?
Votes
Translate
Translate
Report
Report
LEGEND ,
As long as the angles of the shot match, you should be okay.  If they don't, the viewer will smell a rat.
Votes
Translate
Translate
Report
Report
Participant ,
Hi @Dave LaRonde,
thank you for your answer. How can I create such a pallet form like in the image in a white animation mode exactly like the vase? when I click on the vase I got no image but a red coloured outline... As I am a beginner if you can explain me step by step I would really appreciate it.
Nico
Votes
Translate
Translate
Report
Report
Community Expert ,
Jan 18, 2018 Jan 18, 2018
Hi Nico:
I'm getting the impression that you're diving into After Effects and using it without any formal training.  Have you looked into taking a class on motion graphics or on After Effects?  You'd probably benefit from something that's hands on.
-Warren
Votes
Translate
Translate
Report
Report
Participant ,
sorry I do not know what it is, can you provide me some examples please?
Nico
Votes
Translate
Translate
Report
Report
Participant ,
Could be a solution to create a Mask with Illustrator and import it on After Effects?
Nico
Votes
Translate
Translate
Report
Report
Advocate ,
If you want to replace the mask. Copy a new mask from Illustrator, Photoshop or After Effects. Select the Mask or Mask Path and paste in the new mask.
If you want to keyframe the mask then keyframe the Mask Path (turn on the stop watch). Select the Mask Path, go to a new location and paste the new mask in as a keyframe.
If you want to replace the layer with a new source then select the  layer and drag the new object into the timeline from the Project panel. Hold down Option or ALT during the release of the mouse. The mask and any other properties/effects changed or added will be retained on the new image.
Votes
Translate
Translate
Report
Report
Participant ,
Hi @ Katie Houghton,
Thank you a lot for your suggestions,
I created the outline with the Pen Tool on Illustrator. Could you please tell me the next steps in order to save it and import it on After Effect?
Thank you in advance,
Nico
Votes
Translate
Translate
Report
Report
Advocate ,
In illustrator you just select and copy the paths into your clipboard. Go back to After Effects. Then if you are replacing the mask, select the mask or mask path then paste. If you are adding the mask then just select the layer and paste.
Just FYI. Your path is 3 paths so it will create 3 masks. It will come in with a mode of difference (subtract the shape where the paths overlap, otherwise it adds). You can change the mode if you like.
If you are replacing the current mask, it will replace but still add 2 more paths to equal 3 masks. If you add the mask, you will end up with 4 masks. If it is confusing you can always delete the current mask prior to pasting on the layer.
Let me know now if that helps. Basically, just copy and paste.
One more nice gem, if you have one path you can copy it into a spatial property like position and instead of a mask you get a motion path.
Hope that helps!
Votes
Translate
Translate
Report
Report
Participant ,
Hi @Katie Houghton,
Thank you very much for your answer. I pasted it as new mask but as you can see the colour white should be inverted. Is there anyway to do it?
Nico
Votes
Translate
Translate
Report
Report
LEGEND ,
close the mask
Votes
Translate
Translate
Report
Report
Participant ,
Hi @Roei Tzoref
Thank you very much, it solved my Problem. I got it working!!
Nico
Votes
Translate
Translate
Report
Report
Advocate ,
LATEST
Yes. Only closed masks are working masks with a mode.
Votes
Translate
Translate
Report
Report
