3 Replies Latest reply on Jan 19, 2018 12:28 AM by JR_Boulay
    Custom Calculation Script Help Please
    laurieh27704364
      Hello,
      I have no experience with JavaScript. Can someone please help me with a custom calculation for a checkbook register?
      Example of Field Names used on each line of the form:
      Amt1       Dep1     Bal1
      Amt2       Dep2     Bal2
      I've tried the following Simplified Field Notation:  BalanceForward - Amt1 + Dep1. This works on the first line of the form and then auto populates the balance field on each remaining line of the form. If there are no entries (check or deposit) I don't want to see the balance populated.
      I've also tried the following JavaScript with similar results. The below works in the first line (Bal1 field), however when I change the script to reflect different field names it doesn't calculate and returns nothing.
      Example of script in Bal1 field:
      event.value=Number(this.getField("BalanceForward").value)-Number(this.getField("Amt1").val ue)+Number(this.getField("Dep1").value);
      I think I need an If/Else statement in Bal2, Bal3, Bal4, etc. fields, however I don't know how to write it! If there are no entries in Amt2 or Dep2 then no balance (Bal2 field) should appear.
      Thank you!
        • 1. Re: Custom Calculation Script Help Please
          JR_Boulay Adobe Community Professional
          Hi.
          Try this in Bal1 field (not tested):
          var total = (this.getField("BalanceForward").value) - (this.getField("Amt1").value) + (this.getField("Dep1").value);
          if (total != "NaN") {
              event.value = total;
          else {event.value = "";}
          • 2. Re: Custom Calculation Script Help Please
            laurieh27704364 Level 1
            JR,
            Thanks so much! This is much closer than what I was trying.
            This script works on the first line of the form and the beginning balance (BalanceForward field) is auto-populating on all lines of the form. Is it possible to show a zero balance or blank until a check or deposit is entered?
            I copied the script you provided (example below), simply changing the field names for remaining lines. It works, but again ideally I don't want the balance field to populate unless there is an entry made.
            var total = (this.getField("Bal1").value) - (this.getField("Amt2").value) + (this.getField("Dep2").value);
            if (total != "NaN" || total != Infinity  || total != -Infinity) {
            Thanks again. I truly appreciate the help.
            • 3. Re: Custom Calculation Script Help Please
              Try this one:
              if ((this.getField("BalanceForward").value != "") && (this.getField("Amt1").value != "") && (this.getField("Dep1").value != "")) {
