4 Replies Latest reply on Jan 18, 2018 6:09 AM by pradyumanr81199420
    Change layer names so lowercase
    pradyumanr81199420
      Hey guys,
      posting for the first time and i dont know any sort of scripting so would be helpful if anyone can help.
      I want to change each and every layer names to complete lower case. Eg : Picture_Large.png >> picture_large.png
      There around 1000 layers so i hope you understand the difficulty to change it manually. I found a script but it changes it to uppercase and only changes groups and not all layers. Here
      Plz help
        • 1. Re: Change layer names so lowercase
          geppettol66959005 Level 2
          see if this is right for you
          // written by Lukasz Wieczorek at http://lukasz.io
          // Please do not remove this and give credit if you repost. Thanks!
          var layerLength = app.activeDocument.layers.length;
          var docRef  = app.activeDocument;
          for(i = 0; i < layerLength; i++){
             docRef.activeLayer = docRef.layers[i]
             var myName = app.activeDocument.activeLayer.name;
              var newName = myName.toLowerCase();
              docRef.activeLayer.name = newName;
          • 2. Re: Change layer names so lowercase
            pradyumanr81199420 Level 1
            ok so i ran your script and this what happened:
            1. Only the artboard case changed to lowercase
            2. All other unselected or hidden layers were affected.
            3. Didnt changed the layers that were nested inside the groups.
            • 3. Re: Change layer names so lowercase
              r-bin Level 5
              aaaa()
              function aaaa()
                  try {
                      var i = get_layer_count();
                      var end = 1;
                      var ret_ok = true;
                      while (i >= end && process_layer(i)) { --i; }
                      return ret_ok;
                      function get_layer_count()
                          try
                              var r = new ActionReference();
                              r.putEnumerated( charIDToTypeID( "Lyr " ), charIDToTypeID( "Ordn" ), charIDToTypeID( "Trgt" ) );
                              var ret, n;
                              try { ret = executeActionGet(r);                       } catch (e) { alert(e); ret_ok = false; return 0; }
                              try { n   = ret.getInteger(stringIDToTypeID("count")); } catch (e) { alert(e); ret_ok = false; return 0; }
                              r = null;
                              ret = null;
                              try { app.activeDocument.backgroundLayer; } catch(e) { return n; }
                              return n-1;
                      function process_layer(n)
                          try {
                              r.putIndex( charIDToTypeID( "Lyr " ), n);
                              var ret, s;
                              try { ret = executeActionGet(r); } catch(e)  { alert(e); ret_ok = false; return false; }
                              var name = ret.getString(stringIDToTypeID("name"));
                              switch (ret.getEnumerationValue(stringIDToTypeID("layerSection")))
                                  case stringIDToTypeID("layerSectionEnd"):
                                      break;
                                  default:
                                      var name1 = name.toLowerCase();
                                      if (name1 == name) break;
                                      var d1 = new ActionDescriptor();
                                      d1.putReference( charIDToTypeID( "null" ), r );
                                      executeAction( charIDToTypeID( "slct" ), d1, DialogModes.NO ); // because of the bug at least in CS6 - CC2108
        // can't set layer name if layer is not active
                                      ret = new ActionDescriptor();
                                      ret.putString(stringIDToTypeID("name"), name1);
                                      d1.putObject( charIDToTypeID( "T   " ), charIDToTypeID( "Lyr " ), ret );
                                      executeAction( charIDToTypeID( "setd" ), d1, DialogModes.NO );
                                      break;
                              ret = null;
                              return true;
                          catch (e) { alert(e); ret_ok = false; return false; }
                  catch (e) { alert(e); }
              3 people found this helpful
              • 4. Re: Change layer names so lowercase
                It worked!!!
                Thank you so much
