5 Replies Latest reply on Aug 16, 2006 11:40 AM by Newsgroup_User
    Using templates at different folder levels
    Bryan_H
      I have a template for web root level pages located in the \Templates directory. When I attempt to use it one directory level down or more, the path reference to the template does not automatically change so that my template doesn't work. Do I need to create another template from a page at that lower level in order for the path to the template (up at the root level) is correct?
        • 1. Re: Using templates at different folder levels
          Level 7
          >directory.
          > reference
          I create a new child page from my template. The link in the child page
          shows this -
          Template="/Templates/whatever.dwt"
          It's a root relative link that will work anywhere in the site. Is that not
          what you are seeing?
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.dreamweavermx-templates.com - Template Triage!
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
          "Bryan_H" <webforumsuser@macromedia.com> wrote in message
          news:ebicuq$bfl$1@forums.macromedia.com...
          >directory.
          > reference
          > work.
          > order
          • 2. Re: Using templates at different folder levels
            Bryan_H Level 1
            I should have been more specific on my problem, sorry. I have the root-relative paths in my navigation bar located in the non-editable area of the template, so when i create a page on the second folder level down, the navigation link is incorrect, not knowing about the relative change in reference to the root. The reason I put the navigation there was so I could make global find and replace changes to the navigation bar easily. I had hoped that DW realized that the relative paths needed to change when the page location changed, but apparently that doesn't happen. So I am thinking that I need a separate version of the template, depending upon which level of folder in which I am creating the new page-from-template. Is this true or is there a better way to handle this? Thanks for your help in advance.
            • 3. Re: Using templates at different folder levels
              Level 7
              There is no link change relative to the root.
              If I have a link in the template page like this -
              <a href="/folder1/folder2/folder3/whatever.html"
              then I can place the child page anywhere in my site and that link will work.
              > location changed
              It does, and doesn't need to do anything.
              But one of us is clearly confused. Please show me your template and tell me
              which links are a problem.
              news:ebip8a$phi$1@forums.macromedia.com...
              > of
              > the
              > could
              > hoped
              > that I
              > folder
              > there a
              • 4. Re: Using templates at different folder levels
                Bryan_H Level 1
                My template was developed for a root-level page. It has navigation in it. A navigation link might read "/level1/page.htm". When I use the same template for a page2, located two levels down, e.g., /level1/level2/page2.htm, the reference to that navigation link in the resulting template-produced page reads "/Templates/level1/page.htm", so it is doesn't work as it should.
                • 5. Re: Using templates at different folder levels
                  Level 7
                  please give a link to the uploaded template file.
                  The fix, and the concept to get- is that the links should work and be
                  correct IN the template file.
                  Open the template file.
                  Check the links.
                  Fix them.
                  Are these html links?
                  Or are they in a js menu type thing?
                  again- url to the template file.
