• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Need help creating degraded effect
Guest
Jan 19, 2018 Jan 19, 2018
Hello all,
I am very new to photoshop and I can't find a tutorial on how to achieve this effect, perhaps because I am not using the right terminology.
Anyway, I would like to achieve a sort of degraded, aged, photocopied effect on text and images like so: https://imgur.com/a/Ot4aq
If anyone could assist me or point me towards a tutorial I would be very appreciative. Thanks in advance for any help.
Views
534
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Jan 19, 2018 Jan 19, 2018
Start with text layer:
Add a new layer above it and fill it with a light gray.
Clip the gray layer to the text layer by pressing the alt/opt key and clicking between the layers.
Add noise to the gray layer:
if you want bigger grain, press ctrl/cmd-T to transform the gray/grain layer. You can enter in numbers for the size. I entered 300%.
If you want the whites more gray, create curves adjustment layer above the grain layer, clip it to the grain layer, and bring down the highlight end of the curve to
Votes
Translate
Translate
Adobe
Community Expert ,
If you want the whites more gray, create curves adjustment layer above the grain layer, clip it to the grain layer, and bring down the highlight end of the curve to the gray that you want.
Votes
Translate
Translate
Report
Report
Guest
I think this will work. Thanks so much!
Do you think there is some way to make the noise show the underlying background layer? As if the noise were holes in the text?
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
Yes, apply a layer mask to the text layer and copy and paste the grain layer into the layer mask. You won't need the grain mask if you do that.
Votes
Translate
Translate
Report
Report
