1 Reply Latest reply on Feb 8, 2018 10:14 AM by Test Screen Name
    Adobe Reader DC does not display pdf objects having reused object numbers
    roadRunner489
      When the sample pdf file built by successive updates in Appendix G of the PDF Reference v 1.7  (G.6.1-G.6.4) is open by the Adobe Reader DC (or Acrobat DC) the annotations added in Stage 4 having reused pdf object numbers (8, 9) are not shown. The other annotation having a new object number (12) is shown.
      However, if new object numbers are given to the annotations instead of reusing the numbers of deleted objects in Stage 3, then all annotations are shown.
      Imho, the original example seems to be correct, why are the annotations reusing object numbers not shown?
      Using this update instead of the one shown in the PDF Reference displays all annotations correctly (remove empty lines if you cut and paste):
      7 0 obj
      [ 10 0 R
      11 0 R
      13 0 R
      14 0 R
      12 0 R
      endobj
      13 0 obj
      << /Type /Annot
      /Subtype /Text
      /Rect [ 58 657 172 742 ]
      /Contents ( New Text #1 )
      /Open true
      endobj
      14 0 obj
      << /Type /Annot
      /Subtype /Text
      /Rect [ 389 459 570 537 ]
      /Contents ( New Text #2 )
      /Open false
      endobj
      12 0 obj
      << /Type /Annot
      /Subtype /Text
      /Rect [ 44 253 473 337 ]
      /Contents ( New Text #5\203a longer text annotation which we will continue \
      onto a second line )
      /Open true
      endobj
      xref
      0 1
      0000000000 65535 f
      7 3
      0000001860 00000 n
      12 3
      0000002140 00000 n
      0000001914 00000 n
      0000002026 00000 n
      trailer
      << /Size 13
      /Root 1 0 R
      /Prev 1704
      startxref
      2320
      %%EOF
      If you want to check, this is the example file from the PDF Reference (remove empty lines if you cut and paste):
      %PDF-1.4
      1 0 obj
      << /Type /Catalog
      /Outlines 2 0 R
      /Pages 3 0 R
      endobj
      2 0 obj
      << /Type /Outlines
      /Count 0
      endobj
      3 0 obj
      << /Type /Pages
      /Kids [ 4 0 R ]
      /Count 1
      endobj
      4 0 obj
      << /Type /Page
      /Parent 3 0 R
      /MediaBox [ 0 0 612 792 ]
      /Contents 5 0 R
      /Resources << /ProcSet 6 0 R >>
      endobj
      5 0 obj
      << /Length 35 >>
      stream
      %place page marking operators here
      endstream
      endobj
      6 0 obj
      [ /PDF ]
      endobj
      xref
      0 7
      0000000000 65535 f
      0000000009 00000 n
      0000000074 00000 n
      0000000120 00000 n
      0000000179 00000 n
      0000000300 00000 n
      0000000384 00000 n
      trailer
      << /Size 7
      /Root 1 0 R
      startxref
      408
      %%EOF
      4 0 obj
      << /Type /Page
      /Parent 3 0 R
      /Contents 5 0 R
      /Annots 7 0 R
      endobj
      7 0 obj
      [ 8 0 R
      9 0 R
      10 0 R
      11 0 R
      endobj
      8 0 obj
      << /Type /Annot
      /Subtype /Text
      /Rect [ 44 616 162 735 ]
      /Contents ( Text #1 )
      /Open true
      endobj
      9 0 obj
      << /Type /Annot
      /Subtype /Text
      /Rect [ 224 668 457 735 ]
      /Contents ( Text #2 )
      /Open false
      endobj
      10 0 obj
      << /Type /Annot
      /Subtype /Text
      /Rect [ 239 393 328 622 ]
      /Contents ( Text #3 )
      /Open true
      endobj
      11 0 obj
      << /Type /Annot
      /Subtype /Text
      /Rect [ 34 398 225 575 ]
      /Contents ( Text #4 )
      /Open false
      endobj
      xref
      0 1
      0000000000 65535 f
      4 1
      0000000604 00000 n
      7 5
      0000000739 00000 n
      0000000784 00000 n
      0000000891 00000 n
      0000001000 00000 n
      0000001109 00000 n
      trailer
      << /Size 12
      /Root 1 0 R
      /Prev 408
      startxref
      1218
      %%EOF
      10 0 obj
      << /Type /Annot
      /Subtype /Text
      /Contents ( Modified Text #3 )
      /Open true
      endobj
      xref
      0 1
      0000000000 65535 f
      10 1
      0000001434 00000 n
      trailer
      << /Size 12
      /Root 1 0 R
      /Prev 1218
      startxref
      1552
      %%EOF
      7 0 obj
      [ 10 0 R
      11 0 R
      endobj
      xref
      0 1
      0000000008 65535 f
      7 3
      0000001671 00000 n
      0000000009 00001 f
      0000000000 00001 f
      trailer
      << /Size 12
      /Root 1 0 R
      /Prev 1552
      startxref
      1704
      %%EOF
      7 0 obj
      [ 10 0 R
      11 0 R
      8 1 R
      9 1 R
      12 0 R
      endobj
      8 1 obj
      << /Type /Annot
      /Subtype /Text
      /Open true
      endobj
      9 1 obj
      << /Type /Annot
      /Subtype /Text
      /Open false
      endobj
      12 0 obj
      << /Type /Annot
      /Subtype /Text
      /Open true
      endobj
      xref
      0 1
      0000000000 65535 f
      7 3
      0000001860 00000 n
      0000001912 00001 n
      0000002023 00001 n
      12 1
      0000002136 00000 n
      trailer
      << /Size 13
      /Root 1 0 R
      /Prev 1704
      startxref
      2320
      %%EOF
