2 Replies Latest reply on Jan 21, 2018 12:27 PM by robboxxx
    Responsive question
    robboxxx Level 1
      Hi all
      I'm toying with a responsive design and I run into a problem.
      I have a slideshow that "scales" when the browser window is made narrower/wider. Thats fine.
      Underneath that slide show is a title an text that only moves horizontal zo the narrower the browser window is, the larger the gap between the underside of the slideshow and the title/text. Can I make the title/text to move up so that the space is proportional the same automatically? Or do I need to ad a breakpoint and move everything up accordingly?
      I included two pic's in the "before" and "after" state. As you can see there is a huge gap between them.
      Schermafbeelding 2018-01-20 om 18.08.20.pngSchermafbeelding 2018-01-20 om 18.09.16.png
        • 1. Re: Responsive question
          Günter Heißenbüttel Adobe Community Professional
          This should be fixable without using extra breakpoints.
          But since there may be different reasons, could you please do the following:
          • Create a new .muse file with only one responsive breakpoint.
          • Copy the slideshow and the first text box onto it.
          • Delete all images from the slideshow except one.
          • Check if the issue persists (I think, it does).
          • Save this new .muse file and share it with us using Dropbox, CC Files or a similar file sharing service.
          • You may follow these advices: https://forums.adobe.com/docs/DOC-8652
          • 2. Re: Responsive question
            robboxxx Level 1
            Thanks Günter.
            I did copy item after item into a new file. The "problem" was the text file starting with "info". After removing it everything worked fine. I made a new text box and it worked also. Problem solved. I guess some kind of setting was the problem.
            Everything works now moer or less the way I want.
            Thanks for the tip.
