FOUND THE FIX
You was right for what ever reason Premiere Pro fail to import the intro of my video, i removed the intro from the time line and i had a successful export, this is just so weird i guess, i did not have to disable MRQ because i had no idea where to disable it lol,
What exactly does the error say and when does it occur.
Fix whatever is on the timeline at the given time in the error message.
And turn off MRQ if you have a dedicated gpu card.
everything on my time line is how i edit my videos all the time, no different then other times..
FOUND THE FIX
At the bottom of the export settings.
Today 2-4-2018 i got the same error after spending hours editing a 9 minute video any help? i can't render the video and i am stuck
Try to export to xml and open that. I had the same issue but I could work on and export my project easily after this.
Sex c vad
I still have no idea how to get past this issue. No solution has been offered. MRQ was off but still getting the error message. I regretted upgrading. Please provide solutions and not examples of random acts that work.
Having the same issue in Premiere and Encore!!! any leads? not being able to export!
Hello,
After trying everything suggested on this forum. I finally managed to fix the issue.
The issue was actually with the video i was importing for rendering. The end of video already had fading effects/transition (Dip to Black, Audio Fade) which was causing the H.264 render settings to fail. I removed those 2sec at the end put another fading effect on and tried it. Guess What! it worked, not only once but every time i had render the clip after that.
I dont know why the existing fading effect would cause this issue but removing it worked.
Jamil
Im wondering if this is a windows issue? I had the same problem with mine on my windows 10 desktop. But I could not pinpoint the problem eventhough i placed in and out at different points. Error message came up before it hit 1% on progress.
So I saved it on my NAS and opened it on my macbook pro and it exported with no issues.
