24 Replies Latest reply on Jan 29, 2018 9:11 AM by Thom Parker
    change negative numbers to parentheses in an acrobat form
    vigneshs53970460 Level 1
      I'm having one text field (Text1)  and one number field (NumberField) in an acrobat form and I need to pull the data from number field to the text field.
      Sometimes the NumberField value is in negative numbers. So, I need to change the negative numbers to parentheses ().
      var num = this.getField("NumberField").value;
      var str = num.toString();
      var strlen = str.lenght;
      var value1 = util.printf("%, 0 0.2f", num);
      if (num == "") {
      event.value = "This part contains: "
      } else {
      even.value = "This part contains: + value1;
      Above is the script to get the value from number field and formatting decimal as well.
      Please help me to change the negative number to parentheses.
