6 Replies Latest reply on Jun 1, 2018 2:15 PM by sever.s.
    Export fdf using a button javascript
    adamsski168 Level 1
      I have no javascripting knowledge, is it possible to add an export .fdf javascript to a button in a pdf form?
      seems simple but i can't seem to find an example?
      Thansk
      Adamsski168
        • 1. Re: Export fdf using a button javascript
          George_Johnson MVP & Adobe Community Professional
          There are some built-in possibilities (e.g., doc.exportAsFDF), but they don't work with Reader. With Reader you can use JavaScript to build a string that's a complete FDF, but the user would have to somehow copy and paste it into a file.
          • 2. Re: Export fdf using a button javascript
            adamsski168 Level 1
            Hi George,
            thanks for the response. I am using Acrobat Pro and creating my own forms. I just wanted to add an export data button for the users so we can start to build on the data entered.
            Thansk
            Adam
            • 3. Re: Export fdf using a button javascript
              Thom Parker Adobe Community Professional
              .You can use this script in a Button MouseUp Action:
              this.exportAsFDF();
              This displays a file Save As dialog for saving the FDF file. There is an input parameter for setting the file path. This won't work from a button script because specifying a path is a privileged operation. But it would work from an Acrobat DC Command. Look on the Actions panel. There is a feature for creating a new command. You can use this script with an input for saving the file to a specific name and location. Makes it a bit easier on the user, and make the functionality available to any open form.
              • 4. Re: Export fdf using a button javascript
                I may not have been clear, but the doc.exportAsFDF method will only work with Acrobat, so if any of the form users will be using Reader, then this approach won't work.
                • 5. Re: Export fdf using a button javascript
                  adamsski168 Level 1
                  Hi Thom,
                  Thats really helpful thank you.
                  I just need to find the next part lol
                  • 6. Re: Export fdf using a button javascript
                    sever.s. Level 1
                    Hey George,
                    I tried your suggestion with the string that contains FDF ...
                    I used this code and it worked ... not saying that it's optimized but the idea was great.
                    To mention that the script is sending this to a web-service I created that wraps just final terminators...
                    For more details I can be contacted ...
                    Code:
                    var all = "";
                    var fld = "";
                    var d = this.dataObjects;
                    var dn = this.numFields;
                    for (var i = 0; i < dn; i++) {
                        if (this.getNthFieldName(i) != null) {
                            fld = this.getNthFieldName(i);
                            val = this.getField(fld).value;
                            all = all + "<</T(";
                            all = all + fld;
                            all = all + ")";
                            if (val != null) {
                                all = all + "/V(";
                                all = all + val;
                                all = all + ")";
                            all = all + ">>";
                    var contstr = "<</FDF<</F(" + this.path + ")/Fields["
                    contstr = contstr + all;
                    // this I got them from a file ... not sure how to create them
                    var footer = "]/ID[<960596C7FECA907F3E2BB93B81F03C30><08B586C4C0EF3DF1D2490646D78F587B>]/UF(" + this.path + ")>>/Type/Catalog>>"
                    // the string is now ready ... although there are some more lines to wrap in the web-service
                    // fix-header and footer also added in web-service, but all fields were added in the content
                    // according to FDF synthax
                    // prepare call for web-service
                    var err;
                    var err2;
                    var wsaddr = "http://localhost:59843/Service1.asmx?WSDL";
                    var wsaddrfld = "WSAddr";
                    var wsaddrfromfld = "";
                    // filter the characters for SOAP call
                    contstr = contstr + footer;
                    contstr = contstr.replace(/</g, "&lt;");
                    contstr = contstr.replace(/>/g, "&gt;");
                    // call the web-service
                    try {
                        var myURL = wsaddr;
                        try {
                            wsaddrfromfld = this.getField(wsaddrfld).value;
                            myURL = wsaddrfromfld;
                        catch (err2) {
                            app.alert("JSErr.ToGetWebService:" + err2.message + " - at URL:" + myURL);
                        SOAP.wireDump = true;
                        var myProxy = SOAP.connect(myURL);
                        var testString = "<docbinary>This is test</docbinary>";
                        var myStringObject = {
                            soapType: "xsd:string",
                            soapValue: "<docbinary>" + contstr + "</docbinary>"
                        var result = myProxy.SaveDocument(myStringObject);
                    catch (err) {
                        app.alert("JSErr.:" + err.message);
                    // finally - done ...
                    app.alert("File was SENT - JS");
                    // **** EOJ ****
                    Happy coding,
                    Sever
                    svr@rogers.com
