Hello,
Good day.
I can't select/click any effects and presets in Effects and Presets windows. It is greyed out.
I have initially solved this problem by recreating a new account. But problem reoccur again using new account.
Last option i have not tried is to reinstall the application.
TIA
Correct term: Can't click drop-down in any Effects and Presets folder.
Hello,
Would you try to create a simple comp like a single solid image only on the timeline and apply any effects?
Hi Sir ToolfarmJP,
Already tried it.
Even simple composition with single solid image won't work.
I just noticed that I can select/click any effects/presets when i selected alphabetical option to view effects and presets windows.
But when I choose Category option, can't even click any folder to view effects/presets under any category.
Thank you
Double-check your AE CS 6 version in the About dropdown. If it is not at least version 11.0.4, you need to update.
No guarantees if it will solve your problem if if you have a new operating system.
Hi Sir Dave,
I have already updated AE CS6 version to 11.0.4 but still problem exist.
Mac OS version: Sierra
Thank you
rcsjr,
Please reinstall and report back.
Kevin
I have decided to recreate another account once again.
So far issue does not arise.
I will let you know once issue occured again.
