• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
PNG opens incorrectly in Photoshop CC (2018) v19.1
New Here ,
Jan 24, 2018 Jan 24, 2018
I am trying to open a .png file and it won't open correctly.  I've tried multiple different .png files from different sources and no luck.  I've even saved an image from CC and tried to open it with the same results.  Here is screenshot of CC (left) next to CS4 (right) where it opens just fine:
I've searched the web for a solution with, but have found none.  Any help is greatly appreciated!
Views
2.8K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee , Mar 14, 2018 Mar 14, 2018
Hi All,
This problem should be fixed after the Photoshop 19.1.2 update. You can install this update via Creative Cloud desktop app.
Also, you can refer the list of the fixed issues after the Photoshop 19.1.2 update, here: Fixed issues in Adobe Photoshop CC
Regards,
Mohit
Votes
Translate
Translate
Adobe
Community Expert ,
That looks like you may be having a Graphic adapter problem see if there is a newer device driver available for your display adapter. If there is try installing it on you machine.
JJMack
Votes
Translate
Translate
Report
Report
Community Beginner ,
Feb 15, 2018 Feb 15, 2018
what does that mean????
Votes
Translate
Translate
Report
Report
Having this exact issue too. Works fine opening the PNG in any other software (including InDesign and Illustrator), any solutions?
Votes
Translate
Translate
Report
Report
New Here ,
I contacted support and was told it was a bug that would be fixed in a future update.  The solution was to remove v19.1 and then install 19.0.  Less than ideal, but at least my PNG files are behaving properly.
Votes
Translate
Translate
Report
Report
Community Expert ,
Uncheck
Preferences > Plug-Ins > Allow Extensions to Connect to the Internet
Preferences > Plug-Ins > Load Extensions Panels
and restart Photoshop.
Votes
Translate
Translate
Report
Report
This works, thank you.
Votes
Translate
Translate
Report
Report
Community Expert ,
It is a known bug and is being worked on, but maybe add your »Me too«:
Photoshop CC 19.1: PNG Images Opens with Distortion | Photoshop Family Customer Community
Votes
Translate
Translate
Report
Report
Community Expert ,
Thank you—both for the link and for the workaround!
Votes
Translate
Translate
Report
Report
Mar 05, 2018 Mar 05, 2018
This worked for me, however when I went to export my artboards out, I was unable to load that export panel. So had to go back in and recheck this. Does anyone know when an update will be released sorting this out with Photoshop?
Votes
Translate
Translate
Report
Report
Adobe Employee ,
LATEST
Hi All,
Regards,
Mohit
Votes
Translate
Translate
Report
Report
