5 Replies Latest reply on Jan 28, 2018 9:11 PM by CoSA_DaveS
    Stopping eye gitters (when snap eye gaze is off)
    alank99101739 Level 4
      If I sit perfectly still looking at the eyes of my character on the screen, they move. I have eye gaze off as I wanted more eye positions than the 9 the snap function allows. Sometimes it looks like the movement is due to me breathing (slight body movement, results in eye movement).  I have tried fiddling with lots of settings, but I cannot get it so I look directly at the screen without moving and the eyes stay still.
      What I would like for example is a threshold - ignore any eye movement less than X percentage. Is this possible?
        • 1. Re: Stopping eye gitters (when snap eye gaze is off)
          CoSA_DaveS Adobe Employee
          No, but if you increase Smoothing it might calm down the movement enough?
          If we had an option for more than 9 positions, would that be the ideal situation? How many positions would you want?
          • 2. Re: Stopping eye gitters (when snap eye gaze is off)
            I tried smoothing, but I found it still moved around, just...smoother. I still could not make the puppet stare straight ahead. I guess more than 9 positions could help - its still rounding off the position to remove jitters. I guess you would always want to look straight ahead, so it would be 5x5 instead of 3x3 grid? Obviously you could not do all positions with keyboard short cuts any more. However I am not sure it would be worth the effort. Also 5x5 would not give smooth eye pans - it would be jerky ones. I was trying for a smooth eye pan then a hold at the end in whatever direction it was looking at (then more pans etc).
            One thing I discovered after posting this is the “keyboard strength” setting for eye movements. That is, I can change how far the puppet looks to the left. That helped a bit. I can then pan eye positions by blending the keyboard strength maybe... A bit painful to use however.
            Why Am I asking for this?  I just had an example where a puppet’s eyes were trying to track a moving object. It actually looked quite good when the eyes were moving. You could not notice any jitter. Its just when the eyes stopped moving, then jitter became obvious. It is clear the eyes are not holding still.
            Or is there a way to freeze the current eye positions? E.g. record a take, then somehow lay over the top a take that says to “hold position” to lock the eyes. I would not mind having a keyboard trigger for example to freeze current eye position (stop getting inputs from camera) - I look around with my eyes (with smoothing on to help) then press a trigger when my eyes stop moving to tell it “lock the eyes here”. Just kicking around ideas. But a keyboard to lock the eyes plus smoothing might work quite well.
            To me, however its possible, success is being able to do a smooth eye pan then stop moving the eyes and have them look in that direction without any movement (smoothness does not stop movement - just makes the transition smoother) - which is annoying to look at).  Right now the camera, no matter how still I sit looking at one spot on the screen, is picking up eye movements (or making them up when they don’t really exist).
            Thanks for thinking about this!
            • 3. Re: Stopping eye gitters (when snap eye gaze is off)
              I think you'll be able to do what you want by doing this:
              1. disarm Eye Gaze's Camera Input
              2. arm Mouse & Touch Input
              3. turn off Snap Eye Gaze if it's on
              Now you can click and drag in the scene panel to control eye gaze with the mouse and record the full take. This way it's much easier to stop in place. You can still combine with the tracking / keyboard control, and balance them with the Strength parameters (which can also be animated).
              Instead of recording (or in addition), you can also use Timeline > Record 1-frame Take to create a very short take that you can then position in time, add blends, duplicate etc. Like recording, it creates takes for all armed parameters. For inputs like Mouse & Touch Input, the mouse has to be down when you do it.
              In the next release (no ship date yet), there will be a new Timeline > New Hold Take command that will let you create one of these short takes more easily by reading the value already in the timeline, or selected triggers in the trigger panel.
              • 4. Re: Stopping eye gitters (when snap eye gaze is off)
                The record-1-frame option (you mentioned it recently in another thread too) is one I am going to explore more with blending. I do think that has potential.
                Leveraging what is in the timeline already would be useful too - I look forward to that feature. It would be nice at times to hover the cursor or move the timeline pointer and see the current values for a take (e.g. x,y). Not a show stopper, but convenient at times.
                I did not notice for blends the ability to follow beizer or linear (straight line) at the start/end of blends. Normally the current model of smooth transitions is right. But when say walking for a longer blend (to move the puppet between two locations) the gradual transition looks a little funny (puppet velocity slows down, but legs are going at same speed). Having the choice of linear vs curve for blend in/out would be nice (I did not notice it there already). The curved blend is the right default choice. But with blends being effectively key-framing, linear (no curve) is useful at times too. (Or have I missed that one too?). Or maybe ability to control the % length of the in/out blend curve (with 0% being linear). But maybe again New Hold Take maybe I can splice the current take into three and control the blend curve length that way? (Today shorter blends = shorter curves)
                Thanks for the feedback!
                • 5. Re: Stopping eye gitters (when snap eye gaze is off)
                  I've added an option for linear blends to our feature request database, thanks for the suggestion!
