0 Replies Latest reply on Jan 25, 2018 2:09 AM by fmmm
    Adobe XI Pro and "The instruction at 0x refernced memory at 0x. The memory could not be read"
    fmmm
      Hello folks,
      We are generating PDF from MS Access within OLE Object - using Adobe Acrobat XI Pro Trial Version - the code seems working fine when in Debug Mode however in Non Debug it bugs with the following error "The instruction at 0x refernced memory at 0x. The memory could not be read".
      Tried many combinations but no luck - please help.
      Here is the code:
      Header 1
      Private Const GW_CHILD = 5
      Private Const GW_HWNDNEXT = 2
      Private Declare Function GetDesktopWindow Lib "user32" () As Long
      Private Declare Function GetWindow Lib "user32" (ByVal hwnd As Long, ByVal _
      wCmd As Long) As Long
      Private Declare Function GetWindowText Lib "user32" Alias "GetWindowTextA" _
      (ByVal hwnd As Long, ByVal lpString As String, ByVal cch As Long) As Long
      Public Sub test()
          Dim dhwnd As Long      ' desktop window handle
          Dim hwnd As Long       ' window handle
          Dim rval As Long       ' return value
          Dim wname As String    ' window name
          Dim i As Integer
          Dim oXL As Excel.Application
          Dim oWD As Word.Application
          Dim oPP As PowerPoint.Application
          Dim ArcoApp As New Acrobat.AcroApp
          Dim OriPdf As Acrobat.CAcroPDDoc
          Dim avdoc As Acrobat.CAcroAVDoc
          Dim rootFolder As String
          Dim fileName As String
          Dim flag As Boolean
          Set rstSubForm = Forms!dbo_tblDokument!.Form.Recordset
          If CurrentProject.AllForms("dbo_tblDokument").IsLoaded Then
              rootFolder = "D:\Temp\Files\"
              rstSubForm.MoveFirst
              Do While Not rstSubForm.EOF
                  With Forms!dbo_tblDokument!Inhalt
                      On Error Resume Next
                      If Forms!dbo_tblDokument!Inhalt.OLEType = acOLENone Then
                          GoTo last
                      End If
                      If Forms!dbo_tblDokument!DokuID > 68 Then
                          .Verb = acOLEVerbOpen
                          .Action = acOLEActivate
                          dhwnd = GetDesktopWindow()
                          hwnd = GetWindow(dhwnd, GW_CHILD)
                          flag = False
                          Do While hwnd <> 0
                              wname = Space(260)
                              rval = GetWindowText(hwnd, wname, 260)
                              wname = Left(wname, InStr(wname, Chr(0)) - 1)
                              Debug.Print wname
                              If Len(wname) Then
                                  If Trim(wname) Like "*Acrobat*" Then
                                      wbn = wname
                                      Set ArcoApp = CreateObject("AcroExch.App")
                                      Set OriPdf = CreateObject("AcroExch.PDDoc")
                                      fileName = rootFolder & Forms!dbo_tblDokument!DokuID & "_" & wname & ".pdf"
                                      If (Len(fileName) > 73) Then
                                          fileName = Left(fileName, 73)
                                      End If
                                      Debug.Print fileName
                                      Set avdoc = ArcoApp.GetActiveDoc
                                      If Not (avdoc Is Nothing) Then
                                          Set PdDoc = avdoc.GetPDDoc
                                          flag = PdDoc.Save(PDSaveFull, fileName)
                                      End If
                                      OriPdf.Close
                                      ArcoApp.CloseAllDocs
                                      Exit Do
                                  End If
                              End If
                              hwnd = GetWindow(hwnd, GW_HWNDNEXT)
                          Loop
                          If flag = False Then
                              Debug.Print "Document with " & Forms!dbo_tblDokument!DokuID & " Document ID doesnt save"
                          End If
                      End If
                  End With
      last:
                  rstSubForm.MoveNext
              Loop
          End If
          MsgBox "Completed"
      End Sub
