4 Replies Latest reply on Jan 28, 2018 8:47 AM by hala52795350
    Lost Tags
    hala52795350 Level 1
      Problem: Original “Tags” from Elements 10 “lost”, after upgrade to Elements 15.
      Previously I had Adobe Photoshop Elements 10, (APSE10), in which I created and used hundreds of tags. (I have approx. 14,000 photographs.)
      APSE 10 developed a problem in that the various menus became unreadable. I spoke to a tech guy at Best Buy who suggested I upgrade to APSE15, which I did.
      This indeed solved the readability problem but my original tags apparently “disappeared”. I have tried to relocate these tags but without success.
      Any help in re-establishing these tags would be greatly appreciated.
        • 1. Re: Lost Tags
          Bani Verma Adobe Employee
          • 2. Re: Lost Tags
            02GEEK Adobe Community Professional
            Try to find out if the upgrade has wiped your catalogs by search for a file named 'catalog.pse10db'. By default it's in a hidden folder of the C: drive, therefore you  have to set your explorer to show 'hidden' files. If you manage to find one or more folders with such file, each folder will correspond to a catalog.
            Then you  have to use the 'convert' option of the catalog manager to create a catalog in the PSE15 format from your PSE10 catalog
            If you have made backups from the organizer of PSE10, you should be able to recover everything with the 'restore' function of the new Elements.
            • 3. Re: Lost Tags
              Thank you, thank you. The solution you suggested worked perfectly and all of my old tags are restored.
              Thank you again.
              • 4. Re: Lost Tags
                Thank you,
                I have already recovered my tags using the described steps.
                Thanks again.
