1 Reply Latest reply on Jan 13, 2009 2:00 AM by Mouseclick Multimedia
    Flash sprite has to be visible (from YOU !) in authoring mode to   work !
    Level 7
      If this can help (and if you can confirm !).
      I already went through the trouble that you can't put a Flash sprite off
      stage otherwise you loose control over it (you have to keep one pixel on
      stage), but this is more tricky :
      I suddenly had my Flash sprites working only in projector mode and I
      discovered that lower right corner of the stage was not visible (stage
      window was resized), which is where I hide my Flash sprites. As soon as
      I could see the corner, problem was gone in authoring mode !
      PJ
