3 Replies Latest reply on Jan 26, 2018 4:26 AM by c.pfaffenbichler
    Incremental quicksave action
    borgs37069531 Level 1
      Hi there!
      I am creating an action that has 3 basic functions;
      1. Save file with incremental number (ex: figuredrawing001.png)
      2. Close the file (without "are you sure" warning)
      3. Create new document figuredrawing
      This is what I have so far
      I am creating this to quickly save 30 second figure drawings and refresh my canvas.
      I found an ancient script online that did roughly this but for some reason it would stop without error (or notifying me) at 008 for no apparent reason and came with a whole host of other issues. (Like when I tried it after closing photoshop it started overwriting 001 again for instance)
      Is there a way to set this up quickly under a hotkey? For reference this is the script that I was working with.
      // This script will save the active document to a folder with an incremental sufix
      // Change the options below to match your needs
      var saveFolder = new Folder( 'E:/Specialization/30seconddrawing' ); //don't put the ending "/" this is for mac folders windows is /c/foldername
      var saveSufixStart = '_';
      var saveSufixLength = 3;
      saveOptions = new PNGSaveOptions();
      saveOptions.embedColorProfile = true;
      saveOptions.formatOptions = FormatOptions.STANDARDBASELINE;
      saveOptions.matte = MatteType.NONE;
      saveOptions.quality = 8;
      // End of user options
      var saveExt = 'png';
      function zeroPad ( num, digit ){
         var tmp = num.toString();
         while (tmp.length < digit) { tmp = "0" + tmp;}
         return tmp;
      var docName = decodeURI ( activeDocument.name );
      docName = docName.match( /(.*)(\.[^\.]+)/ ) ? docName = docName.match( /(.*)(\.[^\.]+)/ ) : docName = [ docName, docName, undefined ];
      var saveName = docName[ 1 ]; // activeDocument name with out ext
      var files = saveFolder.getFiles( saveName + '*.' + saveExt );// get an array of files matching doc name prefix
      if( files.length == 0 ) {  // no file with that name so start at one
         var saveNumber = 1;
      if( files.length == 1 ) { // one file found, see if it has a sufix
         var fileName = decodeURI ( files[ 0 ].name );
         fileName = fileName.match( /(.*)(\.[^\.]+)/ ) ? fileName = fileName.match( /(.*)(\.[^\.]+)/ ) : fileName = [ fileName, fileName, undefined ];
         if( fileName[1].match( /_(\d{3})$/ ) == null ){
            var saveNumber = 1;// does not have sufix so set to one
         } else{// has sufix
            var saveNumber = parseInt( fileName[ 1 ].match( /_(\d{3})$/ )[1] ) + 1; // strip the ext and get the sufix , convert to number and add 1
      if( files.length > 1 ){
         files.sort();
         var fileName = decodeURI ( files[ files.length -1 ].name );
      var saveFile = new File( saveFolder + '/' + saveName + '_' + zeroPad( saveNumber, saveSufixLength ) + '.' + saveExt );
      activeDocument.saveAs( saveFile, saveOptions ,true ,Extension.LOWERCASE);
