1 Reply Latest reply on May 16, 2008 7:08 PM by abeall
    Slice Name Text Box BIGGER!!!!!!
    KeithHopkin Level 1
      I've been using Fireworks for years. I love it!
      I have one huge pet peeve though and I CANNOT BELIEVE this hasn't been changed after all of this time. I'm using CS3 and the image slice naming textbox is TINY. I can fit 11 characters in it. This thing needs to be at least double the size.. or at least I should be able to pull the area open if need-be.
      It has got to be the most annoying thing in Fireworks.
      Thanks for your time!
      Keith
      NY, NY
        • 1. Re: Slice Name Text Box BIGGER!!!!!!
          abeall Level 3
          You mean the object name in the Properties panel? It is a bit cramped down there, but did you know that's the same thing as the object name in the layers panel? I never use that little textbox for that very reason, I prefer just using the layers panel. Double click the slice name in the layers panel (which by default says "Slice") and you can name it right there, exact same thing as using the Properties panel. And you can even drag out the panel width just like you want. :)
          Hope that helps!
