• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Colour Changing GIF?
New Here ,
Jan 27, 2018 Jan 27, 2018
I was wondering how this gif was created?Gyazo - a7804d1c4f46dd6a373d9ac1fa78b4d9.gif I am hoping to be able t re-create something like that where the effect added on top of the gif is also moving.
Views
771
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Jan 27, 2018 Jan 27, 2018
How much do you know already?
Do you know how to make Frame Animations?
  1. To make the background then consider the black square as your final viewing area or canvas size. You need to start with a much larger canvas with two full repetitions of the pattern.
  2. Copy the layer and use Free Transform to move it to the left by the required amount. One pixel will produces a smooth animation but with a large file sizer.
  3. Now use Shift Ctrl Alt T to make enough new layers to get the repeated same pattern ion the
Votes
Translate
Translate
Adobe
Community Expert ,
  3. Now use Shift Ctrl Alt T to make enough new layers to get the repeated same pattern ion the frame.
  4. Make a frame animation, and then use Make frames from layers.
  1. That's just the moving background of course, so put the layers into a group to keep them tidy.
  2. Make a new group for the foreground animation which has to have exactly the same number of frames as the background.
  3. Now you will need to manually work through frame by frame turning on the foreground layer for the appropriate frame.
It helps enormously if you number the foreground layers with the same numbers as the frames.
Votes
Translate
Translate
Report
Report
LEGEND ,
Another duplicate of How do I add a rainbow 'filter' to a GIF (i.e color changing)?
Please do not start multiple discussions on the same subject, it will get negative reactions and reduce the chance of a good reply. If you do not understand the replies you get, please SAY SO.
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
It drives me crazy.  You spend 15 minutes putting together an annotated response, only to find that someone has already said exactly the same thing in another thread.  As often as not, the OP never revisits the thread, although I see that the OP has done so in response to JJ in the other thread.
Here's a question from me. I followed my own advice to produce this rainbow background.  It is 403 pixels wide, and has 95 frames.  I'd thought that with the soft edges it might be reasonably smooth, but it still has the frame animation flicker.  It's also 8Mb, so is going to take a while to load.  There are moments when it appears to move more smoothly, so what is the secret to flicker free frame animations?  Is there some math that takes monitor refresh time into account?  I doubt it, as it takes about four seconds to move 400 pixels — perhaps that is too close a relationship and speeding it up to three seconds with less frames would work better.  In fact we often see very fast moving animations that appear to move more smoothly than they have any right to.   Is there an answer?
Votes
Translate
Translate
Report
Report
