23 Replies Latest reply on Feb 1, 2018 7:02 AM by rechmbrs
    End of jsx script let user choose when to finish
    rechmbrs Level 1
      We converted an ATN to JSX and in the ATN the STOP command was used.  STOP was converted properly but what is needed in JSX is that stop needs to wait for user to complete the task at that time.  The action leaves things running as is so user can finish and the Click PLAY to resume.  The user is using the select tool when the stop is done.
      Any to do in JSX?
      RONC
        • 1. Re: End of jsx script let user choose when to finish
          Kukurykus Adobe Community Professional
          Post your code (at least that working part with a problem) so I'll make modification. It's hard to talk about thing I don't see.
          • 2. Re: End of jsx script let user choose when to finish
            geppettol66959005 Level 3
            if you want to intervene with a block
            you have to put the block
            example
            step8 (true, true)
            • 3. Re: End of jsx script let user choose when to finish
              I completetly don't understand your answer to him
              • 4. Re: End of jsx script let user choose when to finish
                Kukurykus
                I think I understand that he would like to stop the script
                with a stop like in the example below
                //#target photoshop
                // test.jsx
                // Generated Sun Jan 28 2018 18:15:39 GMT+0100
                cTID = function(s) { return app.charIDToTypeID(s); };
                sTID = function(s) { return app.stringIDToTypeID(s); };
                //==================== test ==============
                function test() {
                  // Crea
                  function step1(enabled, withDialog) {
                    if (enabled != undefined && !enabled)
                      return;
                    var dialogMode = (withDialog ? DialogModes.ALL : DialogModes.NO);
                    var desc1 = new ActionDescriptor();
                    var ref1 = new ActionReference();
                    ref1.putClass(cTID('Lyr '));
                    desc1.putReference(cTID('null'), ref1);
                    executeAction(sTID('make'), desc1, dialogMode);
                  // Unisci visibili
                  function step2(enabled, withDialog) {
                      return;
                    desc1.putBoolean(cTID('Dplc'), true);
                    executeAction(sTID('mergeVisible'), desc1, dialogMode);
                  // Imposta
                  function step3(enabled, withDialog) {
                      return;
                    ref1.putEnumerated(cTID('Lyr '), cTID('Ordn'), cTID('Trgt'));
                    var desc2 = new ActionDescriptor();
                    desc2.putString(cTID('Nm  '), "layer test");
                    desc1.putObject(cTID('T   '), cTID('Lyr '), desc2);
                    executeAction(sTID('set'), desc1, dialogMode);
                  // Crea
                  function step4(enabled, withDialog) {
                      return;
                    ref1.putClass(sTID("contentLayer"));
                    var desc3 = new ActionDescriptor();
                    var desc4 = new ActionDescriptor();
                    desc4.putDouble(cTID('Rd  '), 174.000004827976);
                    desc4.putDouble(cTID('Grn '), 70.2840457856655);
                    desc4.putDouble(cTID('Bl  '), 70.2840457856655);
                    desc3.putObject(cTID('Clr '), sTID("RGBColor"), desc4);
                    desc2.putObject(cTID('Type'), sTID("solidColorLayer"), desc3);
                    desc1.putObject(cTID('Usng'), sTID("contentLayer"), desc2);
                  // Imposta
                  function step5(enabled, withDialog) {
                      return;
                    desc2.putEnumerated(cTID('Md  '), cTID('BlnM'), cTID('SftL'));
                  step1();      //
                  step2();      //
                  step3();      //
                  step4(true, true);
                  step5();      //
                //                    test.main
                test.main = function () {
                  test();
                test.main();
                // EOF
                "test.jsx"
                // EOF
                • 5. Re: End of jsx script let user choose when to finish
                  Ok, I feel stupid now you probably refer to some xbytor2 script I didn't know and he possibly used but didn't mention...
                  • 6. Re: End of jsx script let user choose when to finish
                    rechmbrs Level 1
                    This is part of code and sorry I misstated at end of script.
                    If STOP were at the end it works but unless we STOP it before step 77, the user doesn't have time to finish and no way to signal when finished so that the script can continue.
                    Sorry for my mixup.
                    See my comments in between code segments.
                    RONC
                      function step74(enabled, withDialog)
                          return;
                        ref1.putProperty(PSClass.Channel, PSString.selection);
                        desc1.putReference(PSKey.Target, ref1);
                        desc1.putEnumerated(PSKey.To, PSType.Ordinal, PSEnum.None);
                        executeAction(PSEvent.Set, desc1, dialogMode);
                    // Select
                      function step75(enabled, withDialog)
                          return;
                        ref1.putClass(PSClass.EraserTool);
                        executeAction(PSEvent.Select, desc1, dialogMode);
                    // We would like to complete this step or bypass it entirely with user saying so then continue to step 77.
                    // Stop usage came over from ATN so not same as what I said as they didn't try to bypass step 75
                      // Stop
                      function step76(enabled, withDialog)
                          return;
                        desc1.putString(PSKey.Message,
                          "Stop for fixup.\r\rAfterwards, press Play to continue."
                        desc1.putBoolean(PSKey.Continue, true); // Inserted by RONC  not correct???
                        executeAction(PSEvent.Stop, desc1, dialogMode);
                      // Set
                      function step77(enabled, withDialog)
                          return;
                        ref1.putEnumerated(PSClass.Layer, PSType.Ordinal, PSEnum.Target);
                        var list1 = new ActionList();
                        list1.putEnumerated(PSClass.Channel, PSKey.Red);
                        desc2.putList(PSString.channelRestrictions, list1);
                        desc3.putUnitDouble(PSKey.Scale, PSUnit.Percent, 100);
                        desc2.putObject(PSKey.LayerEffects, PSKey.LayerEffects, desc3);
                        desc1.putObject(PSKey.To, PSClass.Layer, desc2);
                      step74(); // Set
                      step75(); // Select
                      step76(true, true); // Stop
                      step77(); // Set
                    • 7. Re: End of jsx script let user choose when to finish
                      rechmbrs Level 1
                      Have to blame everything on me not xbytor.  Sorry
                      RONC
                      • 8. Re: End of jsx script let user choose when to finish
                        rechmbrs
                        I do not understand English very well
                        if you can explain yourself better on what you want to do
                        we can help you better
                        • 9. Re: End of jsx script let user choose when to finish
                          There are two kinds of stops in Actions.   Stop and Stops with continue.  Both can stop the playing of the action and leave the Action position to start playing at the next step in the action after the stop step.  You can do anytime you want in Photoshop and when done click play to continue the action.  The difference between the two stops is the if you juste wanted to put our a message to the user Stop with conduce allows the user to just to acknowledge that they saw the mess by pressing enter and the action continues. That is like an alert in a script.  There is no concept stop in scripting where a script can be started from a different step.  You would need to program the script with some logic that would know what part of the script to run each time you run it.   I use the document metadata instruction field to record that information.  The first my scripts of this type does is look to see what it has recorded there. If it finds none of its recordings in there it know it the first time the script is being run on this document to do its stuff. So it runs part 1 which notes in the instruction field its information and ends execution which could be a message to the user to do something and run the script again.  The next time the script is run on the document the script will rune the next part. If part is the last part all of the scripts information will be removed from the instruction field and the scrip will end execution.  The  allows the full process  be done more the one time on a document.
                          My script all use the instruction field and do not interfere with each be preserving data in the field which is not theirs.    My scripts for the most part do not put out message and the user does not know they are using the script more than one.  Most of my scripts of the scripts of this type I have were written for use within Actions or toggle function for documents.   They are more or less like save and restore steps for action   One may save the resolution and ruler in use for the Document  in the instruction field. Than action  is free to  scale the document to a known size without reapplying. The resize a watermark for this size document or select a font size for this size document  add the text or watermark then run the script a second time to restore the document resolution  scale it back to it original scale..
                          However Adobe added a bug into scripting in CC 2015.5 and will not allow  you to set the instruction files back to null if it were null to begin with. So I set up script event manager new document and open document event to add garbage to the instruction field if it is not in there so the field will not be null.
                          Adobe add some strang bugs and makes statemnts like its bad to remove copyrights.  I do not understand that for they let your set the copyright to anything yow want to using Photoshop's file info.  I was jsut trying to set the instruction filed to what it was without the scripts information.
                          Jeffrey Tranberry, Sr. Product Manager, Digital Imaging
                          Official Response
                          Hi John, after some investigation, this new behavior is as-designed:
                          From the engineer: This was an intentional change to better preserve metadata during collisions from other applications:
                          "The new logic can lead to some cases where the user deleted information in another application and it reappears in Photoshop because it was not deleted in all instances (we have at least one source for the info, but no idea of the intention behind the change). But that is much safer than deleting added information which was intended (deleting a byline, description, or copyright is BAD)."
                          • 10. Re: End of jsx script let user choose when to finish
                            rechmbrs Level 1
                            Thanks for the response.
                            The script builds a diagnostic as it goes from step to step.  At a point in the script a decision has to be made.  The diagnostic is displayed for the script user to evaluate.  The user should be able to say that the diagnostic is good and that the script should continue on or the user should state that the diagnostic needs more work and the script should allow the user to use the eraser tool to fix the problem and then tell the script to use the corrected image to continue with the same steps as the good image was sent to.
                            Please ignore our script and just consider what I have stated.
                            RONC
                            • 11. Re: End of jsx script let user choose when to finish
                              That's easy but not with script you use. Consider following construction then:
                              #target photoshop
                              if (!$.getenv('continue') {
                                   alert('First steps of script'), $.setenv('continue', 1)
                                   // time to use eraser and continue script hitting button
                                   // or continue script with no prior action by hitting buutton
                              else {
                                   alert('Next steps of script'), $.setenv('continue', '')
                              if statement sets global variable to true. So next time (after script stopped and you used eraser or not) it checks that global variable is set to true. For the script it's command to execute else statement. So you pressed bound button and your script continued with else statement. After all steps of else statement are finished, script sets global variable back to false, so next time you run script it starts working again from if statement. That above sample is working, try it to understand me better...
                              • 12. Re: End of jsx script let user choose when to finish
                                the script could be useful
                                I did not understand how to make it work
                                you could post an example.
                                • 13. Re: End of jsx script let user choose when to finish
                                  This is already very clear example
                                  You put all his steps from first one he uses in script to 74, and then 75 (which I guess choose Eraser Tool). While step 77, and all others there are you put to else statement. When you run script it goes thru all steps to step 75, then it stops. When you rerun script it continues working from step 77. And so on, when you run script once again it starts from step 1 to stop at step 75, to go further from step 77 when you use (or not) Eareser Tool and run script again. But will his script accept this change?
                                  Here's an example done on @geppettol66959005 script who asked me privately to demonstrate how that could be used in his script. Second part is his original script you have to replace 8 steps part (at bottom of script) to this little modification:
                                  if (!$.getenv('continue')) {
                                       step1();      // Crea
                                       step2();      // Unisci visibili
                                       step3();      // Crea
                                       step4();      // Selezione
                                       step5();      // Crea
                                       step6();      // Imposta
                                       step7();      // Selezione
                                  else {
                                       step8();      // Unisci visibili
                                  // script
                                  // TEST
                                  //==================== Azione 1 ==============
                                  function Azione1() {
                                    // Crea
                                        return;
                                    // Unisci visibili
                                        return;
                                    // Crea
                                        return;
                                      ref1.putClass(cTID('AdjL'));
                                      desc2.putClass(cTID('Type'), sTID("vibrance"));
                                      desc1.putObject(cTID('Usng'), cTID('AdjL'), desc2);
                                    // Selezione
                                        return;
                                      ref1.putEnumerated(cTID('Chnl'), cTID('Chnl'), sTID("RGB"));
                                      desc1.putBoolean(cTID('MkVs'), false);
                                      executeAction(sTID('select'), desc1, dialogMode);
                                    // Crea
                                        return;
                                      desc3.putEnumerated(sTID("presetKind"), sTID("presetKindType"), sTID("presetKindDefault"));
                                      desc2.putObject(cTID('Type'), cTID('Crvs'), desc3);
                                    // Imposta
                                    function step6(enabled, withDialog) {
                                        return;
                                      ref1.putEnumerated(cTID('AdjL'), cTID('Ordn'), cTID('Trgt'));
                                      desc2.putEnumerated(sTID("presetKind"), sTID("presetKindType"), sTID("presetKindCustom"));
                                      var ref2 = new ActionReference();
                                      ref2.putEnumerated(cTID('Chnl'), cTID('Chnl'), cTID('Cmps'));
                                      desc3.putReference(cTID('Chnl'), ref2);
                                      var list2 = new ActionList();
                                      desc4.putDouble(cTID('Hrzn'), 0);
                                      desc4.putDouble(cTID('Vrtc'), 0);
                                      list2.putObject(cTID('Pnt '), desc4);
                                      var desc5 = new ActionDescriptor();
                                      desc5.putDouble(cTID('Hrzn'), 73);
                                      desc5.putDouble(cTID('Vrtc'), 50);
                                      list2.putObject(cTID('Pnt '), desc5);
                                      var desc6 = new ActionDescriptor();
                                      desc6.putDouble(cTID('Hrzn'), 191);
                                      desc6.putDouble(cTID('Vrtc'), 218);
                                      list2.putObject(cTID('Pnt '), desc6);
                                      var desc7 = new ActionDescriptor();
                                      desc7.putDouble(cTID('Hrzn'), 255);
                                      desc7.putDouble(cTID('Vrtc'), 255);
                                      list2.putObject(cTID('Pnt '), desc7);
                                      desc3.putList(cTID('Crv '), list2);
                                      list1.putObject(cTID('CrvA'), desc3);
                                      desc2.putList(cTID('Adjs'), list1);
                                      desc1.putObject(cTID('T   '), cTID('Crvs'), desc2);
                                    // Selezione
                                    function step7(enabled, withDialog) {
                                        return;
                                    // Unisci visibili
                                    function step8(enabled, withDialog) {
                                        return;
                                    step1();      // Crea
                                    step3();      // Crea
                                    step5();      // Crea
                                    step6();      // Imposta
                                  //                    Azione1.main
                                  Azione1.main = function () {
                                    Azione1();
                                  Azione1.main();
                                  • 14. Re: End of jsx script let user choose when to finish
                                    rechmbrs Level 1
                                    I'm afraid we get a run time error 24 stating that either Step1(); or Step77(); is not a function.
                                    I've marked our changes by comments.
                                    HELP please,
                                    RONC
                                    if (!$.getenv('continue'))      // added extra )
                                      alert('First steps of script');   //changed , to ;
                                      // or continue script with no prior action by hitting button
                                      step1(true, true); // Stop
                                      step2(); // Flatten Image
                                      step3(); // Image Size
                                      //////////  step4-step70 removed from this not original
                                      step71(); // Set
                                      step72(); // Delete
                                      step73(); // Delete
                                      step74(); // Set Eraser
                                      step75(true, true); // Select
                                    else
                                      alert('Next steps of script');  //changed , to ;
                                      /*      step76(true, true); // Stop    */  //remover from original per instructions
                                      step77(); // Set
                                      step78(); // Hide
                                      //////////  step79-step90 removed from this not original
                                      step91(); // Merge Layers
                                      step92(true, true); // Stop
                                    • 15. Re: End of jsx script let user choose when to finish
                                      excuse my reflection
                                      but you can not use it
                                      step8 (false, false);
                                      to skip the function
                                      • 16. Re: End of jsx script let user choose when to finish
                                        That what you did can't work, because you removed your functions (it's why you're getting that error), and left only steps() parts which call the (not existing right now in your current code) functions. Get back them so maybe that will finally work...
                                        Beside you didn't understand my answer to @geppettol66959005, who btw didn't understand too my last reply (what I'm seeing from his next private message). I didn't mean to replace whole code of him, but only a part to that code I posted:
                                        step1();      // Crea
                                        step3();      // Crea
                                        step5();      // Crea
                                        step6();      // Imposta
                                        A shortened and more readable code won't work too, because there are no functions of your original script, steps call them:
                                             step71(); // Set
                                             step72(); // Delete
                                             step73(); // Delete
                                        else {
                                             step77(); // Set
                                             step78(); // Hide
                                        • 17. Re: End of jsx script let user choose when to finish
                                          rechmbrs Level 1
                                          I didn't remove the actual build of the steps.   I didn't send that part hoping it doesn't matter.
                                          Can't I do this by just save a variable to disk and not using getinv and setinv.
                                          Is there really a problem having true, true or false, false in a function call?
                                          RONC
                                          • 18. Re: End of jsx script let user choose when to finish
                                            That won't change anything you save variables to disk or they will be part of environment. Problem with true, false in function I just solved other way to stop script and continue it, and it's not something I thought up, but xbytor2 so you should ask for him or someone who uses such scripts. If you kept functions in your script but didn't post them here and getting error that function doesn't exist then investigate why that happen. I can not be any of help when I don't see code.
                                            • 19. Re: End of jsx script let user choose when to finish
                                              The basic problem is Action stop brake the action into parts.  Each part is player by the user clicking the play button to play the next part of the action and the same document need to be the active document in the right state.
                                              The easiest way to convert this type of action to a script is use X's action file to script then brake the script produced into the Action Parts.   If there are two stops in an action there would be three scripts.   ActionPart1 ActionPart2 ActionPart3. Instead of clicking the Play button to  play the next part  of the action you run the next script part.
                                              • 20. Re: End of jsx script let user choose when to finish
                                                Either 2 - 3 scripts, or just one with if, else if and/or else statement depending what is stored in 'env' at the time of running.
                                                • 21. Re: End of jsx script let user choose when to finish
                                                  I find it better to store the data in the document metadata,  rather the in a global environment variable or a custom script option . Keep it with the document being worked one.   If you stop execution what to stop the user from  using the script or an action the user the script on an other document and mess with the environment variable or custom script option.
                                                  You also need to know how to code.  Not juste use X's actionfile to script to generate action manager code.
                                                  • 22. Re: End of jsx script let user choose when to finish
                                                    I use both methods to store variables (env and meta), but here a problem is not a method but his ability to use anything that could work whatever he'll decide to use for raliability in future. For now he's figuring out what to do with given tips
                                                    • 23. Re: End of jsx script let user choose when to finish
                                                      rechmbrs Level 1
                                                      Thanks for the help.  After taking in all of the good information from you, we have the script working.  We broke it into portions and many of our problems went away.  Also decided to make the Action work to match script which will be much easier to understand for the users.
                                                      I hit the jackpot with this group.  JJ always has a few that helps so many.
                                                      My appreciation,
                                                      RONC
