3 Replies Latest reply on Jul 11, 2018 7:37 AM by smacdonald2008
    mvn clean install -autoInstallPackage fails due Connection refused
    tim-schwalbe Level 1
      Hello, I am developing locally with an author instance only and it has always worked. But I think I deleted something in my instance and now it fails when I try to deploy the package. Is there any configuration to turn of deployment to publish? It looks strange that maven tries to deploy to http://localhost:4503/
      It already tried a fresh AEM instance and it does also not work. I tried it for the last 4 hours and set everything up as far as I know.
      Does the require a system user? I have deleted the user once and recreated it, but maybe I miss something.
      Is there a maven or AEM config to solve this issue?
      Thanks and regards!
      [INFO] --- content-package-maven-plugin:0.0.23:install (install-package) @ test-com-relaunch.apps ---
      [INFO] Installing test-com-relaunch.apps (C:\dev\projects\test\test-com-new\test-com-relaunch\apps\target\test-com-relaunch.apps-1 .0.0-SNAPSHOT.zip) to http://localhost:4503/crx/packmgr/service.jsp [INFO] HttpMethodDirector - I/O exception (java.net.ConnectException) caught when processing request: Connection refused: connect
      [INFO] HttpMethodDirector - Retrying request
      [INFO] HttpMethodDirector - Retrying request [INFO] HttpMethodDirector - I/O exception (java.net.ConnectException) caught when processing request: Connection refused: connect
      ERROR] Failed to execute goal com.day.jcr.vault:content-package-maven-plugin:0.0.23:install (install-package) on project test-com-relaunch.apps: Connection refused: connect -> [Help 1]
