2 Replies Latest reply on Feb 2, 2018 7:28 AM by vigneshs53970460
    Get exact decimals from one textfield to another textfield
    vigneshs53970460 Level 1
      Is it possible to get the data from one textfield to another textfield. The values  should exactly match as it is for example: ("1.00245" or "1,000.02542" or "1" or "100.00" or "100.20") the result should be the same ("1.00245", 1,000.02542" or "1" or "100.00" or "100.20") and also if it is negative value we should replace as parentheses.
        • 1. Re: Get exact decimals from one textfield to another textfield
          Joel_Geraci Adobe Community Professional
          It is certainly possible to populate one text field with the value of another. In fact, if you just name the fields the same, it happens automatically.
          However, the formatted (displayed) value and the actual value of the field can be very different. your examples have commas, trailing zeros and you are requesting parenthesis for negative numbers. All of this is possible but we'd need to know if you want the actual value that was entered into the first field to be copied to the second and allow the field formatting to take over to generate the parenthesis, commas, and training zeros or if you want the formatted value to be copied.
          Please elaborate on what you want these fields to be used for.
          • 2. Re: Get exact decimals from one textfield to another textfield
            The value will be in the first text filed example: "-100023.2301554" the output should be like the following value (100,023.2301554).
            if the value is "1" or "10" or "100" or "1000" the output should be "1" or "10" or "100" or "1,000".
            if the textfield1 has decimals the textfield2 value should be the same and textfield1 has negative numbers textfield2 should replace with parentheses.
