4 Replies Latest reply on Feb 1, 2018 11:41 AM by natalieb65564495
    Zoom Out Artboard Glitch
    natalieb65564495
      Hey all,
      This started happening after I updated my Photoshop to the 2018 version, so every time I zoom out this happens: Screen Shot 2018-01-30 at 2.15.06 PM.png
      The art board gets weirdly repeated and zoomed out, regardless if there's art on it or not. This only happens if I have any other tool besides the Move tool selected, but it gets rectified if I click the background with the Lasso or Move tool. I can still draw just fine, everything else works, but it's gotten a bit distracting and annoying when I'm working and constantly zooming in and out.
      Anyone else have this problem with the new update? Please help! Thank you!
        • 1. Re: Zoom Out Artboard Glitch
          Akash Sharma Adobe Employee
          Hinatalieb,
          Thanks for sharing this behavior with us. Does the issue persists if you uncheck "Use graphics processor" in the Photoshop> Performance menu?
          Also, have you notices if the issue is limited to only zooming artboards and while using the Lasso or move tool?
          Akash
          • 2. Re: Zoom Out Artboard Glitch
            natalieb65564495 Level 1
            Hi Akash,
            I switch off "Use graphics processor" and it still does do this. It does this regardless of the tool I am initially using and the only way I can get rid of it is if I use the Lasso or Move tool and click on the background.
            • 3. Re: Zoom Out Artboard Glitch
              Thanks for the heads up natalieb,
              Could you please help us with the Photoshop>> Help>>System info report so that we can check the app and system specs?
              ~Akash
              • 4. Re: Zoom Out Artboard Glitch
                Adobe Photoshop Version: 19.1.0 20180116.r.238 2018/01/16: 1153018  x64
                Number of Launches: 18
                Operating System: Mac OS 10.13.3
                System architecture: Intel CPU Family:6, Model:69, Stepping:1 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
                Physical processor count: 2
                Logical processor count: 4
                Processor speed: 2400 MHz
                Built-in memory: 8192 MB
                Free memory: 4056 MB
                Memory available to Photoshop: 6100 MB
                Memory used by Photoshop: 70 %
                Alias Layers: Disabled.
                Modifier Palette: Disabled.
                Highbeam: Enabled.
                Touch Bar Property Feedback: Enabled.
                Image tile size: 128K
                Image cache levels: 4
                Font Preview: Medium
                TextComposer: Latin
                Display: 1
                Main Display
                High DPI Monitor
                Display Bounds: top=0, left=0, bottom=800, right=1280
                OpenGL Drawing: Disabled.
                OpenGL Allow Old GPUs: Not Detected.
                AIFCoreInitialized=1
                AIFOGLInitialized=1
                OGLContextCreated=1
                NumGLGPUs=1
                NumCLGPUs=1
                NumNativeGPUs=1
                glgpu[0].GLVersion="2.1"
                glgpu[0].IsIntegratedGLGPU=0
                glgpu[0].GLMemoryMB=1536
                glgpu[0].GLName="Intel Iris OpenGL Engine"
                glgpu[0].GLVendor="Intel Inc."
                glgpu[0].GLVendorID=32902
                glgpu[0].GLRectTextureSize=16384
                glgpu[0].GLRenderer="Intel Iris OpenGL Engine"
                glgpu[0].GLRendererID=16925953
                glgpu[0].HasGLNPOTSupport=1
                glgpu[0].CanCompileProgramGLSL=1
                glgpu[0].GLFrameBufferOK=1
                glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.20"
                glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1638 4]
                glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
                glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
                glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
                glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
                glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
                glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
                glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
                glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[60]
                glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
                glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
                glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
                clgpu[0].CLPlatformVersion="1.2 (Oct 31 2017 18:30:00)"
                clgpu[0].CLDeviceVersion="1.2 "
                clgpu[0].IsIntegratedCLGPU=1
                clgpu[0].CLMemoryMB=1536
                clgpu[0].CLName="Iris"
                clgpu[0].CLVendor="Intel"
                clgpu[0].CLVendorID=16925952
                clgpu[0].CLDriverVersion="1.2(Dec 19 2017 21:05:44)"
                clgpu[0].CLBandwidth=1.41248e+10
                clgpu[0].CLCompute=161.211
                nativegpu[0].NativeName="Intel Iris Graphics"
                License Type: Subscription
                Serial number: 90970366140334357975
                GUIDBucket:
                Application folder: /Applications/Adobe Photoshop CC 2018/
                Photoshop scratch has async I/O enabled
                Scratch volume(s):
                  Startup, 233.6G, 81.7G free
                Required Plug-ins folder: /Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/Plug-Ins/
                Primary Plug-ins folder: /Applications/Adobe Photoshop CC 2018/Plug-Ins/
                Installed components:
                   dvametadata.framework   dvametadata   11.1.0.0
                   AdobeXMPScript.framework   AdobeXMPScript   79.160451   79.160451
                   ICUUnicode.framework   ICUUnicode   3.61   "gtlib_6.0" "." "21287"
                   ICUConverter.framework   ICUConverter   3.61   "gtlib_6.0" "." "21287"
                   AdobeCrashReporter.framework   AdobeCrashReporter   7.6.0
                   boost_system.framework   boost_system   11.1.0.0
                   AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
                   AdobeACE.framework   AdobeACE   2.20.02.39705   79.589342
                   AdobeOwl.framework   AdobeOwl   5.2.11
                   mediacoreif.framework   mediacoreif   11.1.0.0
                   manta.framework   manta   2.0.00.1   1.
                   dvaunittesting.framework   dvaunittesting   11.1.0.0
                   AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.8.0.34320   79.562390
                   k2.framework   k2   1
                   AIDE.framework   AIDE   1.5.0.36540   79.574279
                   dynamiclink.framework   dynamiclink   11.1.0.0
                   dvametadataUI.framework   dvametadataUI   11.1.0.0
                   UpdaterNotifications.framework   UpdaterNotifications   10.0.0.1   "10.0.0.1"
                   AdobeExtendScript.framework   AdobeExtendScript   4.5.8.1   81.1150526
                   boost_filesystem.framework   boost_filesystem   11.1.0.0
                   AdobeBIB.framework   AdobeBIB   1.2.03.39705   79.589342
                   AdobeXMPFiles.framework   AdobeXMPFiles   79.160451   79.160451
                   AdobeLinguistic.framework      22175
                   dvaplayer.framework   dvaplayer   11.1.0.0
                   PlugPlugOwl.framework   PlugPlugOwl   8.5.0.87
                   AdobeAGM.framework   AdobeAGM   4.30.87.39705   79.589342
                   adobe_caps.framework   adobe_caps   10.0.0.6   1.584361
                   AdobeSVGRE.framework   AdobeSVGRE   6.0   79.588619
                   AdobePDFL.framework   AdobePDFL   15.0.0.38423   79.226411
                   dvacore.framework   dvacore   11.1.0.0
                   AdobePIP.framework   AdobePIP   7.4.1.109.46827
                   AdobePDFSettings.framework   AdobePDFSettings   1.4
                   AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.8.0.34320   79.562390
                   dvatransport.framework   dvatransport   11.1.0.0
                   Cg.framework   NVIDIA Cg
                   boost_signals.framework   boost_signals   11.1.0.0
                   AdobeXMP.framework   AdobeXMPCore   79.160451   79.160451
                   AdobeJP2K.framework   AdobeJP2K   1.2.2.38423   79.266298
                   dvaaudiodevice.framework   dvaaudiodevice   11.1.0.0
                   LogSession.framework   LogSession   7.4.1.109.46827
                   PlugPlugExternalObject.framework      8.5.0.87
                   AdobeScCore.framework   AdobeScCore   4.5.8.1   81.1150526
                   AdobeSVGAGM.framework   AdobeSVGAGM   1.0.0.38473   79.582907
                   dvametadataapi.framework   dvametadataapi   11.1.0.0
                   CITThreading.framework
                   WRServices.framework
                   amtlib.framework   amtlib   10.0.0.221
                   AdobeBIBUtils.framework   AdobeBIBUtils   1.1.39705   79.589342
                   boost_threads.framework   boost_threads   11.1.0.0
                   aif.framework   aif   6.0.00.1   1.
                   AdobeCoolType.framework   AdobeCoolType   5.17.00.39705   79.589342
                   dvamediatypes.framework   dvamediatypes   11.1.0.0
                   AdbePM.framework   AdbePM   2.5.00.377243   1.578146
                   boost_date_time.framework   boost_date_time   11.1.0.0
                   AdobeMPS.framework   AdobeMPS   5.8.1.38423   79.582572
                   dvaui.framework   dvaui   11.1.0.0
                   ahclient.framework   ahclient   3.0.0.6
                   ICUData.framework   ICUData   3.61   "gtlib_6.0" "." "21287"
                   dvamarshal.framework   dvamarshal   11.1.0.0
                Required plug-ins:
                   3D Studio 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
                   Accented Edges 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   Adaptive Wide Angle 19.1, © 2014-2018 Adobe. All rights reserved. - from the file “Adaptive Wide Angle.plugin”
                   Angled Strokes 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   Average 19.1.0  © 1993-2018 Adobe. All rights reserved. - from the file “Average.plugin”
                   Bas Relief 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   BMP 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                   Camera Raw 10.1 (864), Copyright © 2017 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
                   Camera Raw Filter 10.1 (864), Copyright © 2017 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
                   Chalk & Charcoal 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   Chrome 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   Cineon 19.1.0  © 2002-2018 Adobe. All rights reserved. - from the file “Cineon.plugin”
                   Clouds 19.1.0  © 1993-2018 Adobe. All rights reserved. - from the file “Clouds.plugin”
                   Collada DAE 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
                   Color Halftone 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                   Colored Pencil 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   CompuServe GIF 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                   Conté Crayon 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   Craquelure 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   Crop and Straighten Photos 19.1.0  © 2003-2018 Adobe. All rights reserved. - from the file “CropPhotosAuto.plugin”
                   Crop and Straighten Photos Filter 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                   Crosshatch 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   Crystallize 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                   Cutout 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   Dark Strokes 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   De-Interlace 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                   Dicom 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “dicom.plugin”
                   Difference Clouds 19.1.0  © 1993-2018 Adobe. All rights reserved. - from the file “Clouds.plugin”
                   Diffuse Glow 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   Displace 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                   Dry Brush 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   Eazel Acquire 19.1.0  © 2007-2018 Adobe. All rights reserved. - from the file “EazelAcquire.plugin”
                   Entropy 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
                   Export Color Lookup Tables 19.1.0  © 2012-2018 Adobe. All rights reserved. - from the file “Export3DLUT.plugin”
                   Extrude 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                   FastCore Routines 19.1.0  © 1990-2018 Adobe. All rights reserved. - from the file “FastCore.plugin”
                   Fibers 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                   Film Grain 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   Filter Gallery 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   Flash 3D 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
                   Fresco 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   Glass 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   Glowing Edges 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   Google Earth 4 KMZ 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
                   Graphic Pen 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   Halftone Pattern 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   Halide Bottlenecks 19.1.0  © 2018 Adobe. All rights reserved. - from the file “HalideBottlenecks.plugin”
                   HDRMergeUI 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “HDRMergeUI.plugin”
                   HSB/HSL 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                   IFF Format 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                   IGES 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
                   Ink Outlines 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   JPEG 2000 19.1.0  © 2001-2018 Adobe. All rights reserved. - from the file “JPEG2000.plugin”
                   Kurtosis 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
                   Lens Blur 19.1, © 2002-2018 Adobe. All rights reserved. - from the file “Lens Blur.plugin”
                   Lens Correction 19.1, © 2002-2018 Adobe. All rights reserved. - from the file “Lens Correct.plugin”
                   Lens Flare 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                   Liquify 19.1, © 2001-2018 Adobe. All rights reserved. - from the file “Liquify.plugin”
                   Matlab Operation 19.1.0  © 1993-2018 Adobe. All rights reserved. - from the file “ChannelPort.plugin”
                   Maximum 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
                   Mean 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
                   Measurement Core 19.1.0  © 1993-2018 Adobe. All rights reserved. - from the file “MeasurementCore.plugin”
                   Median 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
                   Mezzotint 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                   Minimum 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
                   MMXCore Routines 19.1.0  © 1990-2018 Adobe. All rights reserved. - from the file “MMXCore.plugin”
                   Mosaic Tiles 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   Multiprocessor Support 19.1.0  © 1990-2018 Adobe. All rights reserved. - from the file “MultiProcessor Support.plugin”
                   Neon Glow 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   Note Paper 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   NTSC Colors 19.1.0  © 1993-2018 Adobe. All rights reserved. - from the file “NTSC Colors.plugin”
                   Ocean Ripple 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   OpenEXR 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                   Paint Daubs 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   Palette Knife 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   Patchwork 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   Paths to Illustrator 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                   PCX 19.1.0  © 1989-2018 Adobe. All rights reserved. - from the file “PCX.plugin”
                   Photocopy 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   Photoshop 3D Engine 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “Photoshop3DEngine.plugin”
                   Photoshop Touch ©2013-2018 Adobe. All rights reserved. - from the file “PSDX.plugin”
                   Picture Package Filter 19.1.0  © 1993-2018 Adobe. All rights reserved. - from the file “ChannelPort.plugin”
                   Pinch 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                   Pixar 19.1.0  © 1989-2018 Adobe. All rights reserved. - from the file “Pixar.plugin”
                   Plaster 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   Plastic Wrap 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   PLY 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
                   Pointillize 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                   Polar Coordinates 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                   Portable Bit Map 19.1.0  © 1989-2018 Adobe. All rights reserved. - from the file “PBM.plugin”
                   Poster Edges 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   PRC 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
                   Radial Blur 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                   Radiance 19.1.0  © 2003-2018 Adobe. All rights reserved. - from the file “Radiance.plugin”
                   Range 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
                   Render Color Lookup Grid 19.1.0  © 2012-2018 Adobe. All rights reserved. - from the file “Export3DLUT.plugin”
                   Reticulation 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   Ripple 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                   Rough Pastels 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   Save for Web 19.1, © 1999-2018 Adobe. All rights reserved. - from the file “Save for Web.plugin”
                   ScriptingSupport 19.1.0, © 2002-2018 Adobe. All rights reserved. - from the file “ScriptingSupport.plugin”
                   Shake Reduction 19.1, © 2014-2018 Adobe. All rights reserved. - from the file “Shake Reduction.plugin”
                   Shear 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                   Skewness 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
                   Smart Blur 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                   Smudge Stick 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   Solarize 19.1.0  © 1993-2018 Adobe. All rights reserved. - from the file “Solarize.plugin”
                   Spaces 19.1.0, © 2015-2018 Adobe. All rights reserved. - from the file “Spaces.plugin”
                   Spatter 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   Spherize 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                   Sponge 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   Sprayed Strokes 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   Stained Glass 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   Stamp 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   Standard Deviation 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
                   STL 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
                   Sumi-e 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   Summation 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
                   Targa 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                   Texturizer 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   Tiles 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                   Torn Edges 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   Twirl 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                   U3D 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
                   Underpainting 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   Vanishing Point 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “VanishingPoint.plugin”
                   Variance 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
                   Virtual Reality Modeling Language | VRML 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
                   Water Paper 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   Watercolor 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                   Wave 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                   Wavefront|OBJ 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
                   Wind 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                   Wireless Bitmap 19.1.0  © 1989-2018 Adobe. All rights reserved. - from the file “WBMP.plugin”
                   ZigZag 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                Optional and third party plug-ins: NONE
                Duplicate and Disabled plug-ins: NONE
                Plug-ins that failed to load: NONE
                Extensions:
                   com.adobe.Butler.backend  2.0.0 - from the file “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.Butler.backend/index.html”
                   com.adobe.inapp.purchase  2.11.27 - from the file “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.DesignLibraryPanel.html/purchase.html ”
                   New Document  2.1.0 - from the file “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.ccx.fnft/fnft.html”
                   Libraries  2.11.27 - from the file “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.DesignLibraryPanel.html/index.html”
                   Start  2.1.0 - from the file “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.ccx.start/index.html”
                   Adobe Color Themes  6.1.0 - from the file “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.KulerPanel.html/index.html”
                   Export As  3.1.2 - from the file “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.photoshop.crema/PSPanel/dialog.html”
                   BrushBox  2.0.0 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.derrickbarth.brushbox/ext_1”
                Installed TWAIN devices: NONE
