1 Reply Latest reply on May 5, 2008 11:45 AM by ntsiii
    Datagrid to XML?
    Dizzia
      Hey guys,
      Been looking around all day. Was wondering if someone could point me to a tutorial to generate XML from my datagrid. Also, is it possible to store objects in the XML? If not, I need a storage solution so I can save my datagrid out to a database / server. Open to any solutions (always up for reading up on things).
      As usual, thanks.
      -G
        • 1. Re: Datagrid to XML?
          ntsiii Level 3
          Yes, best thing is to leave the data as XML, no conversion will be necessary. Create an XMLListCollection from the XMLlist that is the result form the e4x expression you use to select the "row" nodes.
          Lots of details to work out, you will need to know what the server-side is expecting before you can craft Flex to send it.
          Tracy
