4 Replies Latest reply on Jan 31, 2018 3:04 PM by johnrellis
    Lightroom CC not filtering on some keywords
    AndyEllen
      My problem...I select a keyword in Lightroom CC, and although there are 152 people keywords assigned, the view shows me none.
      All photos were selected, no additional filters show.  Clicking on other keywords in the list shows proper results.  I am on Release 7.0.1, Windows 7.  I have attached an image which shows my problem.  "Maryanne" is clearly selected, All Photographs are selected, and no other filters are in place
      I appreciate any help.
      Thanks, Andy
        • 1. Re: Lightroom CC not filtering on some keywords
          johnrellis Most Valuable Participant
          I've observed the Metadata browser getting confused a few times over the years. I think you LR Metadata browser may be slightly wedged:
          Those three dots initially appear when you open the Metadata browser, but they should immediately be replaced with this:
          Try these steps in this order:
          - Reboot your computer. That can often fix weirdness in the LR user interface.
          - Reset LR's preferences and then reboot: https://www.lightroomqueen.com/articles-page/how-do-i-reset-lightrooms-preferences/ . Unfortunately, this too often fixes things when LR goes wonky.
          - Click on Custom Filter in the upper-right corner and select Restore Default Presets. This will restore the definition of the built-in presets (without affecting any custom presets you've defined).  Even though you're not using a built-in preset apparently, my experience is that this can cure strange behavior.
          - Try deleting all the columns except the Keyword column. Click on that three-line menu in the upper-right of the column (see above) and then click Remote This Column.
          • 2. Re: Lightroom CC not filtering on some keywords
            AndyEllen Level 1
            I appreciate the nicely detailed answer, John.  Unfortunately I still have the issue after trying:
            1. Simple reboot
            2. Reset Preferences (alt-shift-open Lightroom)
            3. Restore Default Presets
            4. Deleting all columns (first, leaving just keyword, then deleting all but a "none" column, and then adding Keyword and deleting "none"
            I can get to the pictures using Text filtering, but I also get others that have Maryanne in a different form.  Is there something else I can try?
            Thanks, Andy
            • 3. Re: Lightroom CC not filtering on some keywords
              AndyEllen Level 1
              Hi again, John.  I started thinking of what could be unique about those who did not show.  I came up with the fact that I manually added a People keyword without drawing a box around a face.  I thought if the face was incomprehensible, I did not want to mess up Adobe's face AI.
              I reviewed Maryanne, and removed the non-face delineated people keywords.
              Not exactly sure if that was the cause, but it seemed to work.  Thanks for the advice.
              Andy
              • 4. Re: Lightroom CC not filtering on some keywords
                I reviewed Maryanne, and removed the non-face delineated people keywords. Not exactly sure if that was the cause, but it seemed to work.
                It might be related.  Though I just did a simple test, creating a keyword with the Person attribute checked, and the Metadata browser lets me filter on it just fine. So if there's a bug there, it may not be easy to reproduce, and if it can't be reproduced, unfortunately there's not much point in filing a bug report.  It may be that simply removing the keyword and creating a new one, regardless of the Person attribute, is what fixed the issue.
