• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Book Module Showing 'Collecting Information'
LEGEND ,
Jan 31, 2018 Jan 31, 2018
I'm using LR Classic 7.1 on my Windows 7 system and when switching to the Book module a task 'Collecting Information' starts in the upper left corner. If I switch to any other module the task completes in a few seconds, but switching back to the Book module causes it to reappear and start the task again. I've tried numerous settings changes, complete system restart, etc., but this task pops up and hangs near completion every time I switch to the Book module. I did a search and found a few old posts with no solution found so it's not a common issue. I've never used the Book module to create an actual book other than for "test" purposes so it's not a big issue. I just don't like unexplained things that may later cause other issues.
Views
770
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Jan 31, 2018 Jan 31, 2018
I have see the same 'Progress Bar" in the past but cannot remember why!
Most likely answer is that Lightroom is searching through the full database  (catalog) of photos before it builds the book.
I am without an answer, just Questions-
Do you have "All Photographs" selected in the Catalog panel under the Navigator?
Have you created a standard Collection of images to use in the book?
How many photos do you see on the Filmstrip at the base of the Book screen?
I note that the book is still in an "Unsaved
Votes
Translate
Translate
Community Expert ,
I note that the book is still in an "Unsaved" state, have you tried to [Create a Saved Book] and then always work from the "Book" Collection? (not the "Standard" collection)
Regards. My System: Lightroom-Classic 13.2 Photoshop 25.5, ACR 16.2, Lightroom 7.2, Lr-iOS 9.0.1, Bridge 14.0.2, Windows-11.
Votes
Translate
Translate
Report
Report
LEGEND ,
Feb 01, 2018 Feb 01, 2018
LATEST
thank you for the suggestions.Last night I was able to stop the 'Collecting Information' task from launching by saving the currently open test book using 'Create Saved Book.' I restarted LR and all was back to normal until I deleted the book from the Collections panel. This morning I created another small test book with 3 pages, used 'Create Saved Book,' switched to the Library module, and then deleted the book in the Collections panel. This allowed me to remove the test book without causing the 'Collecting Information' task to launch again. Thanks for your help!
If interested this is the issue I was working on when this problem started. It may or may not be related:
How to "Export Book to PDF" with "bleed"
Votes
Translate
Translate
Report
Report
