0 Replies Latest reply on Jan 31, 2018 1:52 PM by mauricet40311126
    Phongap Bulid App´s Javascript won´t work
    mauricet40311126
      Hello there!
      I have create an app via Phonegap.
      In the Browser and the Emulator on the Device, everything is working fine!
      When i Bulid the App and install it on the Device the Script won´t work anymore. Not all Script but the Classes.
      The Code see like this:
      index.html =========================================
      <script type="text/javascript" src="cordova.js"></script>
      <script type="text/javascript" src="js/iscroll.js"></script>
      <script type="text/javascript" src="js/jquery-1.11.1.min.js"></script>
      <script type="text/javascript" src="js/jquery.mobile-1.4.5.min.js"></script>
      <script type="text/javascript" src="js/es6-promise.js"></script>             <<<<------
      <script type="text/javascript" src="js/es6-promise.auto.js"></script>     <<<<----- Try it but don´t help
      <script type="text/javascript" src="js/global.js"></script>
      <script type="text/javascript" src="js/main.js"></script>
      <script type="text/javascript" src="js/index.js"></script>
              app.initialize();
      </script>
      index.js ==========================================
      var app = {
          // Application Constructor
          initialize: function() {
              this.bindEvents();
          // Bind Event Listeners
          // Bind any events that are required on startup. Common events are:
          // 'load', 'deviceready', 'offline', and 'online'.
          bindEvents: function() {
              document.addEventListener('deviceready', this.onDeviceReady, false);
          // deviceready Event Handler
          // The scope of 'this' is the event. In order to call the 'receivedEvent'
          // function, we must explicitly call 'app.receivedEvent(...);'
          onDeviceReady: function() {
              app.receivedEvent('deviceready');
          // Update DOM on a Received Event
          receivedEvent: function(id) {
      alert('test');              <<<<----------------- running!
      let eventListener = new main();      <<<<<<----- don´t running
      main.js ======================================
      class main extends global {
      /* .....................realy lot of Code...................... */
      constructor(elem) {
      super(); // Call global Class
      /* ............a lot of Code........... */
      alert('main Class loadet');
      console.log('main Class Loadet');
      } // end constructor
      } // end class
      I already try to add .jshintrc files to the main folder of the App and the www folder too.
      Inside:
        "esversion": 6
      But don´t help.
      Hope i find help here. Already try to fix it for many hours...
      Looking forward to hear from you.
      Many thanks
