• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
How to take an existing script and apply it to multiple documents
Community Beginner ,
Jan 31, 2018 Jan 31, 2018
I would like to take an existing script, but have it run on multiple documents that I have open (or select from a set of unopened files)
For example, run the ExportAllStories.jsx on multiple documents
Is there a chunk of text I can just copy and paste into it to make this happen?
TOPICS
Scripting
Views
867
Translate
Translate
Report
Report
Community guidelines
community guidelines
Enthusiast ,
When I need something like this, I use this code I wrote sometime ago...
TO RUN IN FILES SAVED IN A FOLDER:
//  Script by Luis Felipe Corullón
//  Contato: lf@corullon.com.br
//  Site: http://lf.corullon.com.br
var myFileFolder = Folder(/*HERE GOES THE DEFAULT FOLDER*/).selectDlg("Select the folder.");
var myDialog = myFileFolder;
if (myDialog != null) {
    var myIDFiles = myFileFolder.getFiles("*.indd");
    alert (myIDFiles.length + " files were found in the selected.","Script by LFCorullón");
    for (var z = 0; z < myIDFiles.length; z++) {
        app.scriptPreferences.userInteractionLevel = UserInteractionLevels.NEVER_INTERACT;
        app.open(File(myIDFiles));
// HERE GOES THE CODE TO BE EXECUTED IN EACH FILE
        app.activeDocument.close(SaveOptions.YES);
        app.scriptPreferences.userInteractionLevel = UserInteractionLevels.INTERACT_WITH_ALL;
TO RUN IN FILES SAVED IN A FOLDER AND ALL SUBFOLDERS:
var myFolder = Folder(/*the specified folder here*/).selectDlg("Select the main folder.");
// se o usuário pressionar OK na JANELA DE DIALOGO
var myDialog = myFolder;
if(myDialog == null){
        alert ("Canceled.","Script by LFCorullón");}
else {
    var myFiles = [];
    GetSubFolders(myFolder);
    alert (myFiles.length + " files found in the main folder and subfolders.","Script by LFCorullón");
//open files in the selected folder and subfolders
for(var i = 0; i < myFiles.length; i++)
//não exibe nenhuma janela de interação.
//turn check links off
app.linkingPreferences.checkLinksAtOpen = false;
    app.open(File(myFiles));
// EXECUTA A AÇÃO EM CADA UM DOS ARQUIVOS DA PASTA SELECIONADA
//turn check links on again
app.linkingPreferences.checkLinksAtOpen = true;
//exibe todas as janelas de interação.
alert (myFiles.length + " files in the main folder and subfolders were processed.","Script by LFCorullón");}
function GetSubFolders(theFolder) {
     var myFileList = theFolder.getFiles();
     for (var i = 0; i < myFileList.length; i++) {
          var myFile = myFileList
          if (myFile instanceof Folder){
               GetSubFolders(myFile);
          else if (myFile instanceof File && myFile.name.match(/\.indd$/i)) {
               myFiles.push(myFile);
Hope it help.
Votes
Translate
Translate
Report
Report
People's Champ ,
Feb 01, 2018 Feb 01, 2018
You may be interested by Kasyan Servetsky​ Batch process Script:
Batch processor
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
Or Peter Kahrel's
Free script Batch convert/export InDesign documents | Peter Kahrel
where you can use its "Run a script" function.
Regards,
Uwe
Votes
Translate
Translate
Report
Report
