1. Re: Could not complete your request.
Mylenium Feb 1, 2018 1:37 AM (in response to alaind6361345)Without system information nobody can tell you much. Start by checking the usual suspects - graphics driver, screen configuration, related PS preference settings.
Mylenium
2. Re: Could not complete your request.
pixxxel schubser Feb 1, 2018 11:58 AM (in response to alaind6361345)1 person found this helpfulHi alaind6361345,
your problem could be similar to this thread: https://forums.adobe.com/thread/2443449
(mostly written in german language)
There is a checklist you can go through step by step (and the solution in the other thread was: to change the workspace eg to Essentials)
When the window is big enough and if you already work in this workspace try to reset this one (menu: Window --> Workspace -> Reset "your workspace") or change to another workspace.
By the way:
Do you use palettes which are not out of box was installed?
3. Re: Could not complete your request.
Blackcollar Feb 1, 2018 12:31 PM (in response to pixxxel schubser)Thank you very much for your looking into this. Indeed, changing the work space to "essentials" has solved the problem. I was using "photography". This never happened before and I hope a fix will come shortly.
Thanks again!
Al
4. Re: Could not complete your request.
pixxxel schubser Feb 1, 2018 12:57 PM (in response to Blackcollar)You're welcome.
Blackcollar schrieb
… and I hope a fix will come shortly …
I never heard, that the problem comes again. That's why …
5. Re: Could not complete your request.
Kukurykus Feb 28, 2018 3:07 PM (in response to alaind6361345)For anyone who wants to get to know why it happens check: There isn't enough room to display this document => bug !
6. Re: Could not complete your request.
Blackcollar Feb 28, 2018 5:18 PM (in response to Kukurykus)I found the solution to my problem though it may not be applicable to all. I moved the tools bar from the right back to the left as per the original layout. Every time I move the toolbar to the right, the same problem occurs.
Hope it helps others
Al
7. Re: Could not complete your request.
Kukurykus Feb 28, 2018 5:41 PM (in response to Blackcollar)That's not everything what happens. When you choose 'View / Fit to Screen' a window is going to be moved to the bottom!
