5 Replies Latest reply on Feb 1, 2018 5:25 AM by davescm
    Effect
    Deniz-2018
      how want to add an effect (white transparent at top) like the photo shown below.
      Can you please help me?
      Regards.
        • 1. Re: Effect
          Simmer1 Adobe Community Professional
          First click the Add Layer Mask Icon at the bottom of your Layers Palette.
          Then Select the Gradient Tool with the colours set to default blank and white.  Make sure your Layer Mask is selected in you Layers Palette and whilst holding done shift draw a straight Line at the top of the screen to achieve this effect.
          I hope this helps,
          Sim
          • 2. Re: Effect
            davescm Adobe Community Professional
            Hi
            Add a layer mask (Layer >Layer Mask > reveal all)
            Click on the mask in the layers panel and use the gradient tool to add a gradient over the image (the gradient will be added to the mask). Where the mask is black the layer becomes transparent, where it is white the layer is visible - grey is semi-transparent.
            That gives you the transparency. If you want white - then add a white layer below the image layer (Layer - New Fill Layer >Solid Color > White)
            Note : If you just want transparency - then you must save in a format that supports transparency such as PSD, TIFF, PNG.  Jpeg does not support transparency.
            Dave
            • 3. Re: Effect
              macpawel Adobe Community Professional
              You can also made it in a little bit different way.
              Open your image
              Add new Adjustments Layer - Solid Color and choose your favorite color (this example - white). By default this Layer is called Color Fill 1
              Press G on your keyboard to select Gradient Tool and set gradient to default black/white
              Finally select mask of your layer (it's added by default) and drag gradient any angle, length you wish
              You can adjust this by draging again and again. You still work on mask
              pawel
              • 4. Re: Effect
                Deniz-2018 Level 1
                I've a photo like this: kooklijnen.jpg
                and i can't do above methods on this photo
                • 5. Re: Effect
                  Hi
                  Of course you can use that method . If a straight gradient does not suit the image then just brush on the mask in black with a soft (0% hardness)  round brush where you want to make it transparent. If you go too far then brush with white to make it opaque.
                  Dave
