• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Structured FrameMaker 14 default zoom
New Here ,
Feb 01, 2018 Feb 01, 2018
How can I set the default zoom to 90%? Help says that default zoom is determined by monitor resolution which sets the zoom to 140%. Even when I save the dita file at 90% zoom, it reopens at 140%.
TOPICS
Structured
Views
403
Translate
Translate
Report
Report
Community guidelines
community guidelines
Explorer , Feb 06, 2018 Feb 06, 2018
Hello John,
What do you mean by "save the dita file" here? Do you mean the working DITA file? If yes, then you are mistaken here. DITA files take settings from template files. They are stored in the below path:
C:\Program Files (x86)\Adobe\Adobe FrameMaker 2017\Structure\xml\DITA_1.2\app\technicalContent\template
You have to make changes in the template xml files located here. For example, if you are working on a task (let's call it co
Votes
Translate
Translate
Explorer ,
LATEST
Hello John,
You have to make changes in the template xml files located here. For example, if you are working on a task (let's call it configuring_procedure.xml), close the working file and then open the task.template.fm file from the templates folder. Here, you set the zoom level to 90%, save and close the template file. Now, if you re-open configuring_procedure.xml, the zoom will be at 90%. The same procedure has to be followed to other types of xml files too like concept, reference etc.
Note: To make changes in the template files, you need to have admin access to the machine.
Votes
Translate
Translate
Report
Report
