6 Replies Latest reply on Feb 1, 2018 11:17 AM by jrosenbomb
    turn multiple layers off and turn one layer on
    jrosenbomb Level 1
      I am working on a pdf file and have gotten to work with hover states (mouse enter, mouse out) and mouse up/down
      The one issue I'm running into is when I keep the state on (showing a layer) on click and making sure if I have any other layer I have previously selected is turned off.
      I did do this by going through each layer and turning it off on mouse up, but I have a lot of layers and that can be a lot to do for each button.  Is there an easier way?
      I tried using on mouse up
      var docOCGs = this.getOCGs();
      for (var x=0; x < docOCGs.length; x++)
          docOCGs[x].state = false;
      ---- and then another action
          if(docOCGs[x].name == "DBC: National")
              docOCGs[x].state = !docOCGs[x].state;
      but it turned off all layers except DBC Natoinal.  and there are some layers that I still want to show.  I tried locking them, but they still become invisible.  I even check "Always Visible" on the properties.
        • 1. Re: turn multiple layers off and turn one layer on
          Thom Parker Adobe Community Professional
          The "state" setting for an OCG layer is the final word, until Acrobat reprocesses the conditions (usually on a page change), then it changes. This is tricky stuff.
          There is a way to group OCGs to make them all go at once. But even with grouping your loops are the correct and only way to control OCGs with JS. If you want some layers to remain visible, then you need to exclude them in the loop.  The best way to do this is to prefix the names so the script can easily sort out the ones it needs to change and the ones it doesn't.
          There are alternative ways to control OCGs. If you look them up in the PDF spec you'll see there are all kinds of visibility triggers, zoom level, language, etc. there is even a way to associate a script with a layer. None of this is controllable from the Acrobat UI.  So I wrote a plug-in that provides this access. If you join the site, you can download it from pdfscripting.com
          • 2. Re: turn multiple layers off and turn one layer on
            jrosenbomb Level 1
            so the only way to make sure I don't have one layer open after clicking another is to turn them all off in separate actions?
            Can I use the same script, turn off all the layers I want (including the one for that button) and then add another action to turn that layer on but put it below it?
            I was wondering how to turn off the layers I want on one script.  right now I do them individually like this
            • 3. Re: turn multiple layers off and turn one layer on
              Have you read this article?
              https://acrobatusers.com/tutorials/create_use_layers
              You don't need separate loops. You can set all the states in just one loop that uses conditionals to set them appropriately.  One of the problems though, as explained in the article, is that often JS is fighting the OCG handler, which is also evaluating conditions to set visibility. So you need to make sure the OCG parameters are set appropriately, and something else that can stabilize the state is to set the initial state value. "OCG.initState".  Set this to the same value as the state.
              • 4. Re: turn multiple layers off and turn one layer on
                jrosenbomb Level 1
                yes, I looked at that.  I think I'm close.  I'm more of a dabbler when it comes to coding so I'm not sure I have all the syntax correct.  if I want to turn off all of the layers before I turn on the one I select, how do I do that loop.  and does it help if layers start with the same title such as "DBC:"
                and if I turn them off, then make another action to turn the one I want on after that.  Could that work?
                • 5. Re: turn multiple layers off and turn one layer on
                  The code can turn the layers on and off in any way you want. I thought that the issue was that you wanted some to not turn off? In this case you need to filter for those layers in the loop. I suggesting the name prefix because it's easy to recognize in the loop.
                  For example:
                      if(docOCGs[x].name.substr(0,4) != "Grp1")
                  In this case all OCGs names that are prefixed with "Grp1" are not affected by the loop that turns off everything else.
                  • 6. Re: turn multiple layers off and turn one layer on
                    jrosenbomb Level 1
                    I think that works.  I put this script first
                        if(docOCGs[x].name.substr(0,4) == "DBC:")
                    and put it first and it turns off everything with that prefix
                    but then I put
                    to toggle that layer.
