This content has been marked as final.
Show 5 replies
1. Re: Determining measurements contained within photo
JJMack Feb 1, 2018 11:14 AM (in response to stevew40884386)Was she the same distance from the camera as the guncase? If she was closer you would have more pixels per inch for her height then the gun case.
2. Re: Determining measurements contained within photo
davescm Feb 1, 2018 11:28 AM (in response to stevew40884386)As JJMack said , it sounds like perspective where closer objects appear bigger.
Try using the Measure tool within the vanishing point filter. You can set a grid to match the perspective then use the measure tool against that grid and it will compensate for the perspective. You can then calculate from there.
Dave
3. Re: Determining measurements contained within photo
stevew40884386 Feb 1, 2018 11:42 AM (in response to JJMack)No, she was 2-3 feet in front of it.
4. Re: Determining measurements contained within photo
stevew40884386 Feb 1, 2018 11:46 AM (in response to davescm)Thanks. I appreciate it.
5. Re: Determining measurements contained within photo
stevew40884386 Feb 1, 2018 11:47 AM (in response to JJMack)Thanks, I appreciate your help. Just starting out.
