1. Re: How to make 3 different sized canvases, which lets you work on one and affects the others at the same time.
macpawel Feb 1, 2018 10:40 AM (in response to jamiel85489458)You can prepare 3 different canvas (as you wish) and then prepare largest design (some layers, masks, texts, vectors) as a single Smart Object placed to all of your canvas. You can also use external PSD file linked as Smart Object to all of your canvas.
Then open all canvas and smart object (use split view to see all documents) and make changes to smart object.If you save this all of your canvases will update
pawel
3. Re: How to make 3 different sized canvases, which lets you work on one and affects the others at the same time.
Michael J. Hoffman Feb 1, 2018 10:59 AM (in response to jamiel85489458)First, create multiple artboards of the desired size within a single document.
Then, use Smart Objects as macpawel suggested above to replicate the content to each artboard, scaling as needed.
If you want to have multiple views of the same file in Photoshop (for example, you are working a close-up detail on one monitor, and want to have the full image as a reference on a second monitor, or in this case, viewing one artboard and seeing the changes on a different artboard):
Window > Arrange > New Window for [file name]
You can create multiple windows for a single file, and can use Window > Arrange to tile or cascade them, or just drag the tabs to the desired locations.
Mike
4. Re: How to make 3 different sized canvases, which lets you work on one and affects the others at the same time.
JJMack Feb 1, 2018 11:03 AM (in response to Michael J. Hoffman)Seems like doing it the hard way to me. If all have the same aspect ratio and content.
5. Re: How to make 3 different sized canvases, which lets you work on one and affects the others at the same time.
jamiel85489458 Feb 2, 2018 6:28 AM (in response to jamiel85489458)Hi everyone,
Thank you so much for all of your help, I really appreciate it
Thank you,
Jamie.
