5 Replies Latest reply on Feb 8, 2018 8:45 AM by c.pfaffenbichler
    Find midpoint of irregular shaped area
    michaelp62688706
      Hi everyone
      can anyone help me with this problem?
      I have several of these irregular shaped areas. Now I would need to calculate the midpoint of the areas in question.
      Does anyone have a tutorial or similar how I could do that?
      the picture below is an example:
      Thanks a lot
      Cheers
        • 1. Re: Find midpoint of irregular shaped area
          That sounds like something for a specialist tool, not a photo editor. You also need to consider that "midpoint" is ambiguous:
          * centre of gravity (if this were a solid of uniform density)
          * centre of the smallest containing rectangle aligned with grid
          * centre of the smallest containing circle
          * point at the centre of the longest line between two points on the outside boundary
          * average of a large number of x,y sample points randomly or uniformly arranged inside the shape
          * or many more...
          • 2. Re: Find midpoint of irregular shaped area
            Trevor.Dennis Adobe Community Professional (Moderator)
            Hi Michael
            I'm wondering what criteria you would use to decide on the midpoint?  I keep coming back to it being half way between the extremities when considering the object as a rectangle.  If you were to select the area and copy to a new layer.  Using Free Transform would place the centre handle at that half way point.  Making a copy and reducing it in size, will cause it to reduce around that same centre handle.
            I don't think this can be what you are looking for, so it would help — me at least — to know what criteria you want to use.
            • 3. Re: Find midpoint of irregular shaped area
              davescm Adobe Community Professional
              If you want to find the centre of gravity - which would normally be considered the midpoint of an irregular shape, you can do it in Photoshop although it is a little awkward.
              1. Draw around your shape with the pen tool to create a shape and fill it with a solid color. Then turn off your image layer.
              2. Use Select color range to make a selection of your color and in the histogram, expanded view, ensure Cache level is 1 (if not click the triangle at the top right of the histogram). Then read the number of pixels (in my case 4836668)
              3. Calculate half that number of pixels - so for me 2418334
              4. Add a white rectangle shape just above the irregular shape layer and position the edge approximately halfway down.
              5. Press Ctrl+D to Deselect and select color range again
              6.Read the number of pixels in the histogram - remember you must be at cache level 1 so click the warning triangle if not.
              7. Move the white rectangle up/down and repeat steps 5 & 6 until you have as close as possible half the pixels as calculated in 3.
              8. Drag a guide from the ruler an position it on the edge
              9. Move the rectangle so it's vertical edge is across the shape and repeat steps 4-8
              10. Your guides are in the centre of gravity so you can now turn off the shape layers and turn the image back on
              Like I said - it is a bit awkward - but it does work.
              I hope that helps
              Dave
              2 people found this helpful
              • 4. Re: Find midpoint of irregular shaped area
                c.pfaffenbichler Level 8
                Good one.
                It should be possible to script something on the basis of that approach bit it might not be exactly speedy.
                • 5. Re: Find midpoint of irregular shaped area
                  The below Script intends to mark that point for a black area on white with two guides (no guarantees, though).
                  // mark »center« on black are on white.
                  // based on paul riggott’s code for raw image assessment;
                  // 2018, use it at your own risk;
                  #target photoshop
                  File.prototype.readByte = function() {
                  return this.read(1).charCodeAt(0);
                  if (app.documents.length > 0) {
                  var originalRulerUnits = app.preferences.rulerUnits;
                  app.preferences.rulerUnits = Units.PIXELS;
                  var myDocument = app.activeDocument;
                  var theDup = myDocument.duplicate ("dup", true);
                  theDup.changeMode (ChangeMode.GRAYSCALE);
                  theDup.layers[0].posterize(2);
                  theDup.selection.load(theDup.channels[0], SelectionType.REPLACE, true);
                  theDup.selection.expand(2);
                  var theBounds = theDup.selection.bounds;
                  theDup.crop(theBounds);
                  theDup.changeMode (ChangeMode.LAB);
                  var theResult = somethingSomething();
                  theDup.close (SaveOptions.DONOTSAVECHANGES);
                  activeDocument = myDocument;
                  myDocument.guides.add(Direction.VERTICAL, theResult[4] + theBounds[0]);
                  myDocument.guides.add(Direction.HORIZONTAL, theResult[5] + theBounds[1]);
                  app.preferences.rulerUnits = originalRulerUnits;
                  function convertByteToSignedByte(num){
                  var dec = (num | (num % 256))-128
                  return dec;
                  function convertByteToLum( num){
                  var dec = Math.round((num/256)*100);
                  return dec;
                  // get arrays of sums of non-white pixels per line and column;
                  function somethingSomething (){
                  if(!documents.length) return;
                  if(activeDocument.mode != DocumentMode.LAB) {
                      alert("Please convert this document to Lab mode\r Then re-run this script");
                      return;
                  var Name = decodeURI(app.activeDocument.name).replace(/\.[^\.]+$/, '');
                  try{
                  var Path = activeDocument.path;
                  }catch(e){var Path = '~/Desktop';}
                  var rawFile = new File(Path +"/"+Name +".raw");
                  saveAsRaw(rawFile);
                  var len = 0;
                  var W = activeDocument.width.as('px');
                  CountW=0;
                  CountH=0;
                  rawFile.encoding = 'BINARY';
                  rawFile.open('r');
                  // result arrays;
                  var theLines = new Array;
                  var theColumns = new Array;
                  for (var y = 0; y < W; y++) {theColumns.push(0)};
                  var theLine = 0;
                  ////// work through //////
                  while(!rawFile.eof){
                  var theL = 100-(convertByteToLum(rawFile.readByte()));
                  var theA = convertByteToSignedByte(rawFile.readByte());
                  var theB = convertByteToSignedByte(rawFile.readByte());
                  len++;
                  theColumns[CountW] = theColumns[CountW]+theL/100;
                  // new line;
                  if(len % W == 0){
                  theLines.push(theLine);
                  theLine = 0;
                  CountH++;
                  CountW=0;
                  }else{
                  CountW++;
                  theLine = theLine + (theL/100);
                  // remove raw file;
                  rawFile.close();
                  rawFile.remove();
                  var theSum = 0;
                  var theSumColumn = 0;
                  for (var x = 0; x < theLines.length; x++) {theSum = theSum + theLines[x]};
                  for (var x = 0; x < theColumns.length; x++) {theSumColumn = theSumColumn + theColumns[x]};
                  var resultHor = midValue (theLines, theSum);
                  var resultVer = midValue (theColumns, theSumColumn);
                  activeDocument.guides.removeAll();
                  activeDocument.guides.add(Direction.VERTICAL, resultVer);
                  activeDocument.guides.add(Direction.HORIZONTAL, resultHor);
                  // return results;
                  return [theLines, theSum, theColumns, theSumColumn, resultVer, resultHor]
                  function saveAsRaw(file) {
                  var desc1 = new ActionDescriptor();
                  var desc2 = new ActionDescriptor();
                  desc2.putString( charIDToTypeID('FlCr'), "8BIM" );
                  desc2.putBoolean( charIDToTypeID('ChnI'), true );
                  desc1.putObject( charIDToTypeID('As  '), charIDToTypeID('Rw  '), desc2 );
                  desc1.putPath( charIDToTypeID('In  '), new File( file ) );
                  desc1.putBoolean( charIDToTypeID('Cpy '), true );
                  executeAction( charIDToTypeID('save'), desc1, DialogModes.NO );
                  function midValue (theArray, theSum) {
                  var theX = 0;
                  var theHalf = theSum/2;
                  for (var n = 0; n < theArray.length; n++) {
                  theX = theX + theArray[n];
                  if (theX == theHalf) {return n+1};
                  if (theX > theHalf) {
                  var thePercentage = theX/theSum;
                  var theDiff = 0.5 + ( ( (theSum - theX) / theSum) - ( (theX - theArray[n]) / theSum) ) * 0.5 / (theArray[n] / theSum);
                  return n+theDiff};
