• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Reverse Engineering Possible?
New Here ,
May 15, 2008 May 15, 2008
Is there a way to reverse engineer a complete robohelp project back into robohelp to make updates?
Views
776
Translate
Translate
Report
Report
Community guidelines
community guidelines
Explorer ,
Murfrider,
Two questions: What output are you working with? and What version of RH?
If it's CHM, there's a great free tool called "KeyTools" at http://www.keyworks.net/ that I've used. Just point to the chm you want to decomile into HTML files, then tell it where you want to save the files. Easy and fast.
If it's WebHelp, well, I wouldn't recommend trying to "reverse engineer" it. Someone over here inadvertently imported an HTML file from a WebHelp output and they screwed up the project (we're still using RH X5). In this case, if you have no other choice, I would somehow try to clean up the HTML files (maybe use Dreamweaver) before you import them into a new RH project. I haven't gotten my hands on the production version of RH 7 yet - maybe they have better clean up tools. You could also view the files in IE/Firefox then copy the content into new RH topics, but that would be tedious also.
Either way you look at it, it won't be a "push a button and go" kind of thing, though that would be great, wouldn't it?
Maybe Peter or Rick will chime in to give better advice. If you have a choice of outputs to work from, I'd go for a CHM.
Jim
Votes
Translate
Translate
Report
Report
New Here ,
No luck on the CHM, it's all html. The project was done in RH5, I have RH6, not sure if that helps or hurts. Like you said it looks like I'd have to bring in the html one at a time, way too tedious.
Votes
Translate
Translate
Report
Report
Valorous Hero ,
Hi Murfrider
You are probably going to be interested in the following links:
Link number one
Link number two
Cheers... Rick
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
Thanks Rick, I forwarded the link to the guy who really has to fix this problem, heehee. I may play with it a bit if I get a chance.
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
