Hello-
Using Acrobat Pro and have added an acro form digital signature field to a PDF. I'm working with a provider that requires that I add several custom properties to the field for additional parameters that they must receive, read, and apply as part of the signature path within their signing tool.
I do not see anywhere within the UI to add a custom property, so I started digging into field tags and believe this is where I can add the property, but I'm not sure which key/value/value types to apply to add the properties to the field.
The output of the form field would look something like this prior to adding custom properties:
2 0 obj <</MK<</BC[0 0 0]/BG[1 1 1]>>/F 4/Type/Annot/Border[0 0 0]/Subtype/Widget/Rect[20 37 209 70]/SignerName(Signer)/FT/Sig/DR<<>>/T(Signature in Box 15)/AP<</N 1 0 R>>/P 3 0 R>> endobj,
I need to add the custom properties to the field, which would make the output look something like this (see ESHPROP references):
75 0 obj <</ESHPROPrequired(true)/F 4/Type/Annot/Border[0 0 0]/ESHPROPtype(sig)/Subtype/Widget/SignerName(Signer)/DR<<>>/T(Signature in Box 15)/AP<</N 74 0 R>>/P 21 0 R/ESHPROPlabel(Signature in Box 15)/MK<</BC[0 0 0]/BG[1 1 1]>>/Rect[20 37 209 70]/FT/Sig/ESHPROProle(Signer)>> endobj
Any idea what I need to do to get these custom properties into the field so the receiving API/service can read it?
Screenshot of the tag UI where I think I can add these custom properties attached.
Help appreciated!
There is nothing in the UI for editing low level content in a PDF. This is the realm of a custom plug-in. But your requirement is unusual, perhaps unique. Is it definitely the widget dictionary they need updated, rather than the (more typical) custom signature dictionary? These are things only signature implementors become involved in. But since they are looking for these fields they may already have an implementation infrastructure.
Thanks so much for the feedback. I'll play around with the widget dictionary and see if I can apply the custom properties there. These properties are simply descriptions for the receiving service to read, so do you think the value type is just a string value type, name value type, etc?
Thanks!
String value types are what I'd guess but you shouldn't have to guess such an unusual thing...
