I'm running Lightroom Version CC 2015.7, the most current version I can update to, Starting a few weeks ago, every time I try to import from the SD card slot on my iMac, Lightroom immediately crashes. This does not occur when I import from my XQD card when it is inserted into an adapter which is plugged into a USB slot. Any suggestions?
reset your preferences - https://helpx.adobe.com/lightroom/help/setting-preferences-lightroom.html
[moved from Adobe Creative Cloud to Lightroom Classic CC]
This was the fix. Simple. Thanks!!
you're welcome.
the link is broken and im having ehe same issues and i cant figure out how to reset the preferences
This is a better option.
https://www.lightroomqueen.com/how-do-i-reset-lightrooms-preferences/
Press ALT in the PREFERENCES > GENERAL tab. A hidden button appears(*Adobe!!! Bad user interface design!!!)
Reset preferences there...
I have a similar problem. When I open the import dialogue, it is very slow and often crashes. So it might take 30 - 60 seconds for the import dialog to populate.
It takes a long time to respond when I hit the import button, if - indeed - it responds at all.
Resetting the preferences doesn't help.
This problem seems to have developed in the last month so.
This is a major problem
One possible cause is that your hardware (card reader/card/USB Cable) has gone bad. Try different hardware.
Thanks for this.
Mine is actually built in, but I don't think it's this. I can access the card through windows without any difficulty and - when the import actually starts - it's quite fast,
